Hello there
Has anyone tried to use external flash for K-01 with good results.
I already owned a Sigma EF-500 DG SUPER as I have used both the * ist DL and K20D without problems. But on my K-01 so it will not work properly. The flash will fire short after image capture, or sometimes not at all. This results in dark image, because the camera thinks that the flash will illuminate the subject. I can not change the mode on the flash, when mounted on the camera, but it works to change to manual mode and then mount the flash on the camera again, but it seems that it is always full strength despite setting example. 1/32 strength.
