Originally posted by benpo19 I have been researching compact mirror-less cameras for over a month. I came across this deal.
PENTAX K-01 with DA L 18-55 & 50-200 Dual Lens kit for $540.99
The camera has almost all of the features I wanted in my device so I pulled the trigger.
Here is the problem the more I think about it I wonder a few things.
1. Was this as good of a deal as I think it is? I have heard mixed things about the DA L 18-55 and good things about the DA L 50-200 (mostly that it is amazing between 75-125). Would I have been better buying just the body then buying individual lenses?
2. This is my first "real" camera. Should I have gone with a DSLR or with one of the slimmer competitors in the mirror-less market.
3. I own ZERO lenses. Owning lenses already seems to be a big factor for most of the people purchasing this camera. So am I making the wrong call if I am starting from scratch anyway?
Thanks in advance for your opinions
My opinion:
1. As you haven't already invested in a DSLR system, you probably have little to loose - except control over your financial outlay on lenses - regardless of which make you selected. All systems have good and bad points from lens point of view. The main advantage of the Pentax system is that (provided you are happy to use some manual functions) you have access to several decades of lenses that will fit your new camera - and ALL of them will benefit from Image Stabilisation as that is "in camera"
2. From a UK pricing point of view that was a really good deal and for a new user to the world of interchangeable lenses I think you will have a lot of fun with what you have acquired.
3. Because the K-01 works so well at high ISO settings, you will be able to make a lot of use of those lenses. Much more so than on a system such as the Samsung NX range and others where high ISO performance is quite poor. I'm often using either a Tamron 18-250mm F6.3 or Tamron 70-300mm F5.6 lens on mine which means I need all that extra ISO capability to get acceptable images in the poor winter light here in the UK. But I'm getting some excellent photos of birds in my garden that I know no other of my cameras could deliver at this time of year.
4. There ARE some limitations of using the K-01, but for someone coming from a non-SLR/DSLR background I doubt you will notice the main one that troubles a lot of people. The lack of a separate viewfinder causes many to dismiss this camera, but I have no such problems. There are one or two situations where it would be useful but the number of times where having an efficient liveview screen has saved the day for me means I almost exclusively use this camera now rather than one of my DSLRs. If I have any criticisms they are relatively minor and can be addressed by workarounds. The main one I have is the lack of a remote lead socket and the only Infrared remote sensor being on the front. This is a little bit of a pain when taking night photos, but it can ba managed by using the 2 second shutter delay.
So overall - yes I think you got a good deal and will enjoy the camera. And I recommend you start trying out using RAW format to tweak the most you can out what this camera can do for you. I'm sure people will help you on this forum if you ask.
Neil
