At work, I have two cameras; mine (K-01 40mm XS) & a Canon EOS 500D (18-55)
Lighting is rubbish & the color rendition on my K-01 40mm is infinitely better than tha 500D
However; when I bounce the built-in flash (off the ceiling), i usually either get a bit under-exposed or, the real issue, a
blue tint over-cast on the entire picture and the colors are VERY faded compared to the crappy, worn out 18-55mm on the EOS
I know no one really uses the built-in flash but would the issue be due to poor CRI of the built in flash or white balance? or what?
P.S: by bouncing the flash i mean i put a folded piece of paper; a little light gets diffused and the most gets reflected & bounced off the white ceiling
Reason: Remove swearing
