12-20-2012, 11:42 AM   #1
Looking for Macro Kmount reverse adapter for the K-01smc PENTAX DA 40mm F2.8mm XS
This is a very nice lens and I want to try it out for macro photography be reversing it but I am unable to find the proper size adapter for K mount Pentax cameras.
This is the 40mm lens that was made for the K-01 camera.
PentaxWebstore.com:smc PENTAX DA 40mm F2.8mm XS smc PENTAX DA 40mm F2.8mm XS
I think it would work out nicely for macro photography. Adapter needs to go from Kmount spec to threaded 27mm to fit it. I can't find this size of adapter.
Please help.
12-20-2012, 12:55 PM   #2
Senior Moderator
Nass's Avatar
Bear in mind that it has no aperture ring and only 5 elements... But if you are set on this, ebay is probably your friend, a merchant called jinfinance usually has everything you need for obscure adapters. I have bought endless things through him. You want a combo, something like k to 49 then 49 to 27. Make sure you get the male/female thing right =)
12-20-2012, 01:17 PM   #3
cali92rs's Avatar
QuoteOriginally posted by Nass Quote
+1...
there are thousands of available el cheapo 50mm's w/aperture rings that would yield much better results.
12-20-2012, 02:45 PM   #4
I plan on making the aperture stick wide open.
I have a K to 49 but I can't find the 49 to 27.
If anyone sees one please post a link.
This piece shouldn't cost more than $10.
I have a perfectly fine prime 40mm and I don't see any reason to buy another lens. I bought the Q with this lens to use it.
12-20-2012, 05:12 PM   #5
Senior Moderator
Nass's Avatar
Try looking for a k to 52 and 52 to 27 on ebay. There's a lot more stuff around for 52 than 49
12-20-2012, 07:51 PM   #6
I looked and looked and couldn't find anything for 52mm to 27 either.
I really just want a single PK mount to male 27mm adapter. That would be perfect. Somebody please make it.
12-21-2012, 02:37 AM   #7
Not a Number's Avatar
K to 52mm reverse adapter + 27-52mm step-up ring:
52mm Macro Reverse Adapter Ring for Pentax K PK Mount | eBay
27 52mm 27 52 27mm to 52mm Step Up Ring Filter Adapter | eBay
or
27 52 mm 27 to 52 27mm 52mm Step Up Filter Ring Adapter | eBay
or use two step-up rings with your k to 49mm reverse ring:
37 49mm Step Up Metal Adapter Ring 37mm Lens to 49mm Accessory | eBay
27 37mm Step Up Metal Adapter Ring 27mm Lens to 37 mm Accessory | eBay
If you can find them from the same vendor it would be better shipping-wise. I did not try to match vendors. Stacking two step-up rings will add a few millimeters but shouldn't have much of an effect.
I recommend you get a set of lens filter wrenches too. These are invaluable and will save you much frustration trying to improvise something to remove jammed filters and rings. I keep a set of them in my camera bag.
Camera Lens Filter Wrench 2 Set 49mm 58mm 67mm 77mm 72 | eBay
12-21-2012, 06:01 AM   #8
Thanks not a #.
Looks like a good fix for what I want to do.
40mm, adapter, da, f2.8mm, k-01, k01, macro, mirrorless, pentax, pentax da 40mm, pentax k-01, xs
Cap holder for Pentax-DA 40mm F2.8 XS lens mastermisho Pentax K-01 5 07-22-2013 10:23 AM
Pentax Normal Lens Shootout- 40mm ltd, 40mm xs, 35mm f2.4 Adam Pentax SLR Lens Discussion 6 07-11-2012 08:09 AM
Pentax K-01 + 40mm xs for 399 euro RonHendriks1966 Pentax Price Watch 5 06-30-2012 10:03 AM
For Sale - Sold: DA 40mm F2.8 XS relyt Sold Items 7 06-06-2012 05:24 PM
Is there a comparison between the DA 40mm LTD and the 40mm XS out there anywhere? ChopperCharles Pentax SLR Lens Discussion 9 05-07-2012 11:07 AM
All times are GMT -7. The time now is 04:53 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
