12-23-2012, 02:20 AM   #1
AF Select mode. Am I missing something?
Just got a K-01 as an early Xmas present (already own a K-5)
It's pretty neat, but had a quick question
For AF on my K-5 I use the "SEL" function and pick which of the 11 points I wanna focus on pretty much exclusively
Does the "AF Select" mode work like this on the K-01? I do what instruction manual states but it focuses on on the AF'd area, not displaying a screen like it shows. Am I missing something? I have it set on AF Select. Do I have something turned on/off I should/shouldn't? I've been playing with it all day and can't seem to move the auto focus box around (or even get to the screen)
Any help is appreciated!
Thanks!
12-23-2012, 02:23 AM   #2
QuoteOriginally posted by Codazzle Quote
Thanks!
You can, but it works a bit differently. What you do is you select the size of the AF area, and then move it around within the center of the frame. So if you have a 5x5 AF area, you can't move it at all, but if you dial it down to 4x4 you would be able to.
Here's a screenshot of how to access select mode:
Pentax K-01 Camera Review - Autofocus Performance - PentaxForums.com
12-23-2012, 06:38 AM   #3
Na Horuk's Avatar
Be sure you have the AF/MF switch near the lens turned to AF. Now you have a square on the screen. When you AF it will try to find the most contrasty zone in that square. Hit the OK button, now you can spin the silver radial button to make the square bigger or smaller (I prefer it smaller to avoid the camera choosing to focus on more contrasty things instead of the subject I want). Once it is smaller you can move it around using the 4 buttons to the right of the screen. You effectively have more possible AF points than the K-5, but it can take longer to move the square to a precise point. If you are using a fast lens you should also turn on Focus Peaking in the menu, so you can see what exactly is in focus.
And when you have the camera set to MF mode, hitting the OK button will "zoom in" and expand the area where you are trying to focus, so you can use peaking more precisely.
12-23-2012, 01:04 PM   #4
D'oh, figured out my issue. The manual was telling me to push the MENU or Shutter release button halfway after selecting the AF Select. I thought this meant while composing! But it was just to get out of the menu screens!! I was pushing and holding the shutter release halfway then hitting OK and going to the AF Zoom instead of hitting OK before hand :P
Thanks guys!
af, focus, k-01, k-5, k01, mirrorless, mode, pentax k-01, screen
Select Mode AF Area Size Adjustment? Accuracy chaosteo Pentax K-01 3 07-12-2012 08:25 AM
Pentax VS the World: Am I Missing Something Here? Biff Pentax DSLR Discussion 50 07-13-2009 08:22 PM
Todays k-7 'am I missing something' thread Andrew Faires Pentax DSLR Discussion 2 07-10-2009 07:59 PM
Am I missing something? 28-90mm Peter Zack Pentax SLR Lens Discussion 8 06-10-2007 12:15 PM
Variable vs. fixed aperture zooms: am I missing something here? Finn Pentax SLR Lens Discussion 11 05-15-2007 05:05 AM
All times are GMT -7. The time now is 12:22 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
