Not Working for me!
Inspired by this thread I decided to set up remote using Sony rm-vz320 remote control.
Set up the code in the remote control per instructions - scanned codes until camera took a shot in IR.
That worked.
Set k-01 menu to open or close shutter on each shutter press and set camera to IR mode and turned knob to bulb.
Well it worked half away - shutter opens when remote power is pressed, but will not close on second press.
It does work as advertised in other modes - if I press on shutter button manually, and aslo remote works in non-bulb mode.
I wonder if it's the remote or something is not set up right.
I have latest firmware.
BTW, if I keep pressing on remote power button shutter stays down! Also I can confirm that TV remotes do work pretty long distances.
Anyone experiencing this?
