Hi all,
So this P&S upgrader is slowly learning about his new K-01, taking a bunch of test shots with various lenses and under different circumstances. I really love the camera and the image quality is day and night compared to the camera that the K-01 is replacing. My quibbles so far are few - mostly I wish that there was a tiltable LCD and that I could assign "focus zoom" to either the green or red button. This would make it much easier to manually focus heavy legacy zooms while holding the camera two handed at hip level. As-is, even with focus peaking, manual focusing is not altogether easy, as I need to reach to the back of the cam to hit the OK button to focus properly, a gesture that feels awkward, and I need to hold the camera fairly high in order to see the LCD screen, something not so easy with a heavy lens+camera combination.
Anyway, on to my real question. One difference between a P&S and the K-01 is the adjustability of the depth of field. I am having the issue that indoors, when set to automatic, the camera tends to often shoot with lenses wide open, which produces a very shallow depth of field, which can sometimes be a nuisance and not what I have in mind. So I'm trying to use aperture priority to control depth of field. The problem is that the camera seems to have difficulty with exposure in aperture priority mode. In the example below, I first took a picture in auto mode (using a manual focus, Vivitar 28mm PKA lens). That picture came out good, but some elements, notably the wooden frog at bottom left, were out of focus, due to shallow depth of field. So I went into aperture priority mode and adjusted down to F/10, and took the picture again. (Note that I'm not using a tripod so the two pics aren't exactly the same, but they are very close.) The result (below) looks quite washed out and over exposed.
Is this something I just need to compensate "manually" for by tweaking the EV setting down a little? Do I need to remember than in Aperture Priority (with this lens), I need to tune the EV down a little? Will my this behavior vary from lens to lens? Or does it also depend on the lighting at the time of the shot and I just need to review and re-shoot if necessary?
BTW, I am running firmware 1.01.
Thanks for any clues,
Doundounba
