01-02-2013, 12:35 PM   #1
What autofocus method do you use?
Just got my K-01 only because it was a bargain. Liking it more than I thought I would. One thing I do not like - the shutter button, not distinct enough. I'm sure I will get used to it.
A question I have for all of you is, what autofocus method are you using? I have left it in the default so far, face detection. When you know that you are not taking pics of people, would it work faster to use another method? Generally, on my DSLRs, I use centerpoint and recompose. Is that faster focusing? Also, is there no concept of AF-C on this cam? One last question, have any of you used the tracking method? Does it work well? Thanks!
01-02-2013, 12:43 PM   #2
QuoteOriginally posted by jake14mw Quote
There is no AF-C, and the tracking is pretty bad. The K-01 is definitely not a camera for shooting (or focusing on, rather) stuff that moves.
I found that the best AF mode was sel with a 25-point square in the center of the frame.
01-02-2013, 12:48 PM   #3
Na Horuk's Avatar
Welcome!
I would suggest you stay away from face detection, it is not very reliable. Tracking is also not very great. I have it on AF select. Just hit OK and move the square around (scroll to make it smallest as possible) and shoot. That way you can choose exactly where you want to shoot, something you can't even do with DSLRs (since they have just a couple AF points).
Also, if you are using fast prime lenses, you can try focus peaking and manual focusing.
01-02-2013, 12:50 PM   #4
You say that, but I was shooting dance mops this weekend and was having more luck with the k-01 in live view than with my K30! Somewhat surprised me! Admittedly, you have to be a bit smart with it, ie lock focus then pull the trigger nd nature sufficient DOF to give you some leeway, but it wasn't arduous. I'll post some pics in a bit!
Sure, maybe shooting a formula1 race close up as the cars go past might be a reach, and I wasn't using tele distances, but I was using the Tamron 17-50mm which is screwdrive.
I was using a in inaction of face detect and select/adjustable focus point, set to a wider box than the single point mode.
01-02-2013, 03:18 PM   #5
Ikarus's Avatar
I'm old-fashioned, so for me it's the good old spot focus. Face-detection obviously makes no sense, except in cases of there being a single face in the frame. Select mode is too slow. I'm much faster re-composing away from the center spot. I'm aware of the field curvature pitfall when doing this, but this hasn't been a problem with any of my AF lenses, probably because they aren't capable of the shallow DOF anyway that I'm able to get from my manual focus glass.
01-02-2013, 04:47 PM   #6
Na Horuk's Avatar
Well unless you are using a slow lens, focus peaking should also help with confirming focus, so you can fire off when the subject is in-focus, or just quickly adjust.
But yes, AF is one of the places where mirrorless cameras and the K-01 have the most to improve.
01-03-2013, 07:12 PM   #7
Manual focus. dial in with FP, zoom -- re-dial, zoom out, remeter (green button) snap. Pentax M 50mm 1.7. works well for me.
autofocus, k-01, k01, method, mirrorless, pentax k-01, question
Landscapes - what focussing method do you use TylerD Troubleshooting and Beginner Help 11 08-17-2012 08:13 AM
What are your most used lens and what do you use them for? What lens do you have that pearsaab Pentax K-5 44 06-04-2012 09:23 AM
What method do u use of keeping track of images taken with different lenses? altopiet Pentax DSLR Discussion 19 08-02-2011 10:32 PM
What fixer do you use? Nesster Film Processing, Scanning, and Darkroom 49 02-11-2011 11:45 AM
How many tripods do you own and what lenses/purpose do you use them for? gofour3 Pentax Camera and Field Accessories 17 04-09-2010 03:08 AM
All times are GMT -7. The time now is 03:57 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
