01-04-2013, 11:51 PM   #1
Hi Speed Raw on K-01
Don't know if anyone else has discovered this but...
I shoot a lot of HDR. That means everything is exposure bracketed. I also shoot hand held which means I need a high frame rate. I thought when I got the K-01 that would mean I'd have to shoot jpeg to get a high speed burst out of the camera for bracketing. And that's what I've been doing since I got the camera a week ago.
Today I was doing some portraits of my daughter at the local botanical gardens so I had the drive in single shot mode and the file format in raw. I saw a scene that I wanted to HDR so I set the drive on exposure bracket. I forgot to change to jpeg because it's not part of my routine yet. Anyway, the camera fired off the three shots in rapid succession. It was 6 frames per second speed, just like I would expect when shooting jpegs. Except I realized after that I wasn't shooting jpegs, it was RAW! So the camera can do a high speed burst of raw for at least 3 frames.
After this I tried raw+jpeg and it shot high speed also as a bracket. It didn't sound quite as fast as raw alone but it was definitely faster than the 1 frame per second I thought I should get. So now the camera is a much better tool for me for HDR. And if you wanted to get a 3 frame raw burst you could bracket at 1/3 stop and just adjust in post. Kind of mickey mouse but it can be done.
When I got home I tried the same thing on my Q. No go there. 1 frame per second on raw when bracketing. So I'll have to keep using jpeg on it for HDR.
01-04-2013, 11:59 PM   #2
QuoteOriginally posted by post_eos Quote
The K-01 has a fast processor- I believe they've just down-tuned it because of the K-01's low price. Once they put it in a high-end DSLR I'm sure they'll unlock its full power!
01-05-2013, 02:48 AM   #3
As they did in the K-30?
01-05-2013, 03:58 AM   #4
RonHendriks1966's Avatar
I use it mainly for portraits, to have that all eyes open shot:
https://www.pentaxforums.com/forums/pentax-k-01/188844-raw-3-frames-6fps.html
01-05-2013, 08:20 AM   #5
Na Horuk's Avatar
Would be great if they added it in a firmware update. Especially because of the CD AF, this might be a great option. Just spam away with the photos until you get a couple in focus.
01-05-2013, 10:18 AM   #6
Simply allowing bracketing to Zero (0) EV would be all that is necessary !
01-07-2013, 02:28 PM   #7
If you have already updated the firmaware, maybe you should try setting the AF to spot. Works way better instead of it focusing on whatever random point when you press the shutter release.
01-07-2013, 09:35 PM   #8
Na Horuk's Avatar
Oh, I know that the K-01's focusing is usually very accurate, but it is often too slow on moving objects, and a fast burst rate might help there
bracket, burst, camera, frame, frames, hdr, jpeg, jpegs, k-01, k01, mirrorless, pentax k-01, shot
K-01 AF speed with DA* 300 David07 Pentax K-01 6 12-04-2012 10:58 AM
K-01 maximum flash sync speed? truonganh Pentax K-01 6 11-15-2012 11:36 AM
K-01 AF speed looktime Pentax K-01 9 11-14-2012 10:15 AM
Post your K-01 Lens AF speed here pinholecam Pentax K-01 41 07-30-2012 06:58 AM
K-01 AF speed hegedus Pentax K-01 31 02-17-2012 06:51 AM
All times are GMT -7. The time now is 06:18 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
