01-16-2013, 05:22 AM   #1
K-01 video
I do lot of wedding / event photography with my K10 & K20 for many yrs.6 months ago, I bought K-01 for videography on weddings. Well, I am the only one uses K01 among all my friends & they are suprised to see my video camera. I am very happy with result of the video. I made my money in 2 assignments & going strong. I attach GGS view finder for easy framing & manual focus 95% of the time.
01-16-2013, 07:22 AM   #2
klkitchens's Avatar
Nice... that's the main reason I keep the K-01 is for its video abilities.
Thanks for sharing!
01-16-2013, 07:49 AM   #3
jwc77's Avatar
Curious about the GGS view finder...what do you think of it on the K-01? I have been thinking about getting one but am unsure of how well it works. Also...is it permanent or how easily removable is it? Any thoughts on it would be appreciated. Thanks.
01-16-2013, 10:23 AM   #4
ScooterMaxi Jim's Avatar
GGS Perfect viewfinder
Optically, the 3x flippable viewfinder is very good - especially at its price point (about $55-60). For video work, it is a great addition; nice diopter correction, excellent optically. The fit on the K-01 is just right, giving you a ridge to rest your thumb along the row of buttons, and as a thumb rest in the upper right corner. (You attach the mounting screen semi-permanently so the ridge remains in place even when not using the VF itself; the mounting screen seems to be far more scratch-resistant than the K-01 LCD screen.)
The only problem with the GGS system unaltered is that the mounting screen adhesive does deteriorate fairly quickly, and it most likely will finally fail during a longer shooting session as the heat of the LCD causes the adhesive to loosen. The solution - which I would advise implementing at the time of first mounting - is the use of clear 100% silicone sealant on the mounting screen edges (after removing the original adhesive). Applied carefully, and trimmed properly, a silicone seal can look essentially OEM. Even if you make a mistake, it is easy to totally remove the silicone using a blade with care and pealing with your thumbnail; even if the silicone has totally dried. Probably the best silicone is Permatex clear RTV or DAP RTV auto/marine, but I used DAP window/door sealant which worked fine, as well.
01-16-2013, 12:40 PM   #5
jwc77's Avatar
Thanks for the info...just what I needed to hear.
01-16-2013, 07:43 PM   #6
I have the same problem with the adhesive being soft after some time.So, I use super glue to permanently stick it on my lcd. Minor damage on lcd outer part but no effects on the images. I planning to buy ]Aputure Gigtube - Tilt & Swivel LCD Viewfinder for low / high angle shot & also to use with slider or dolly.
PENTAX K20D  Photo
PENTAX K20D  Photo
01-16-2013, 07:51 PM   #7
do you use the Movie Shake Reduction feature for movies? I heard it causes blur, especially at 24fps and full HD.
01-16-2013, 09:50 PM   #8
QuoteOriginally posted by mpmetro Quote
No, I dont use SR at all.It cause kind of jello effect. I always shoot at 1080 x 720 @ 50fps at 1/60 or 1/100. I use motion stabiliser during fast moving shots & tripod rest of the time. My tripod act as tripod,monopod,shoulder pad,slider & dolly. I will be testing the Aputure Gigtube - Tilt & Swivel LCD Viewfinder this week before buying. It need some modification as the mini usb port of K01 is is smaller than the standard cable --- most made for Canikon.
01-16-2013, 10:59 PM   #9
may i ask what kind of motion stabilizer you use?
For the USB cable, are you using the pentax AV out cable? I think the pentax usb port might be proprietary. So perhaps you can get the video out cable, and connect it to the external monitor.
I've used the av cable I had and it shows live view on a tv from my k01
video only
http://www.bhphotovideo.com/c/product/376673-REG/Pentax_39262_I_VC28_Video_Cable.html
audio/video
http://www.bhphotovideo.com/c/product/278392-REG/Pentax_39552_I_AVC7_A_V_Cable.html
01-16-2013, 11:50 PM   #10
I've used the av cable I had and it shows live view on a tv.
video only
Pentax I-VC28 Video Cable 39262 B&H Photo Video
audio/video
Amazon.com: Pentax I-AVC7, AV Interface Cable for Penatx Q and Optio Digital Cameras.: Camera & Photo
motion pro stabilizer
. Need some practice .
k-01, k01, mirrorless, pentax k-01, video
Does k-01 refocus with half press during video like k-30? chiane Pentax K-01 2 11-12-2012 07:15 PM
Last video I made with K-01 : DragonCon 2012 Music Video minilink Pentax K-01 3 09-20-2012 08:48 AM
The Wedding Speech - New HQ K-01 Video + a behind the scenes video solar1 Pentax K-01 21 05-02-2012 11:24 PM
K-01 Video Test SweetPixels Pentax K-01 15 03-11-2012 06:16 AM
K-01 video mode thread jogiba Video and Pentax HDSLRs 16 03-10-2012 06:46 AM
All times are GMT -7. The time now is 02:27 AM. | See also: NikonForums.com, part of our network of photo forums!
