01-17-2013, 11:12 AM   #1
Filter for 40 XS and k01
Hi all. My wife figures out a pretty neat way to put a filter/hood(small one)/and lens cap on the 40XS: The filter is called 'The Digital Guardian' in 27mm size(it's a UV filter), and has a built-in small hood. The hood is part of the aluminum filter ring and it take a 37mm pinch cap. Pictures included:
PENTAX K-5 II s  Photo
01-17-2013, 11:13 AM   #2
Oh, it's made by Kenko.
David
01-17-2013, 11:13 AM   #3
Double oops: The hood is bought separately, does not come with the filter.
01-17-2013, 11:13 AM   #4
seventysixersfan's Avatar
looks quite nice!
01-17-2013, 11:29 AM - 1 Like   #5
Docrwm's Avatar
Why not just put a step up ring on it for $5 that you can get nearly anywhere? One of the reasons I kept the 40 Limited instead of the XS is that it takes 49mm, because 27mm is so limiting.
01-17-2013, 11:46 AM   #6
Na Horuk's Avatar
Ah nice. I ordered a massa 27mm filter as a cap replacement some months ago, but never received it. I thought Id keep it on for protection and just remove it if it degraded IQ too much.
Can you post a sample 100% crop taken without and with the filter/hood combo?
01-17-2013, 11:53 AM - 2 Likes   #7
mrNewt's Avatar
You have some options for the 27mm thread.
A nice and cheap hood:
F124 Metal Lens Hood Sun Shade 27mm For Pentax K-01 kit w/ DA 40mm lens New | eBay
And if you want to get funky:
27mm 0.3x Fisheye Lens Hood, Filter Kit for JVC GZ-MG20,GZ-MG30U,GR-D870,USA,NEW | eBay
More filters:
http://www.ebay.ca/itm/Opteka-HD-Professional-5-Piece-Filter-Kit-UV-CPL-FL-N...ht_3768wt_1139
And, some cheap caps if you lose the original one (or want to keep it safe at home):
http://www.ebay.ca/itm/2X-27MM-SIDE-PINCH-LENS-CAP-FOR-FILTERS-DC-NEW-HOT-/1...9af5a27&_uhb=1
06-24-2013, 02:41 PM   #8
Here my noob questions are, after my deep research on the internet, i'm still very unexperienced.
My choice would be a K01 right now, i'll probably buy them.
Is there any chance to use the XS lens with large polarizing filter?
Does this stuff make sense and compatiblity: 27 52mm 27 52 27mm to 52mm Step Up Ring Filter Adapter | eBay
This adapter for a Marumi 52mm circular polar filter.
06-24-2013, 03:01 PM - 1 Like   #9
Na Horuk's Avatar
QuoteOriginally posted by angevoi Quote
Does this stuff make sense and compatiblity: 27 52mm 27 52 27mm to 52mm Step Up Ring Filter Adapter | eBay This adapter for a Marumi 52mm circular polar filter.
It will be awkward, but it should work. If there are too many step up/down rings and filters, it can cause vignetting, but it probably won't with a 40mm f2.8 lens.
You can even use the 52mm filter handheld in front of the lens btw.
06-25-2013, 03:11 AM   #10
Probably a nice filter for the XS 40mm :
37mm hoya circular polarizing filter:
Genuine NEW Hoya 37mm CPL CIR-PL Circular Polarizing Filter | eBay
Thinner is better noname 27mm to 37mm adapter
Step Up Ring 27-37mm Adapterring | eBay
cap, filter, hood, k-01, k01, mirrorless, pentax k-01
k 01 and 40 xs fist impresion Vindemiatrix Pentax K-01 4 12-19-2012 02:27 PM
40 XS vs DA 40 sewebster Pentax SLR Lens Discussion 81 12-03-2012 08:49 AM
B + W UV XS Pro Filter too wide for 50-200mm lens hood Zomboo Pentax SLR Lens Discussion 2 09-05-2012 08:29 PM
DA 40/2.8 XS reviewed by dxomark Laurentiu Cristofor Pentax SLR Lens Discussion 28 06-10-2012 06:32 AM
35 dal or 40 xs? HoBykoYan Pentax SLR Lens Discussion 9 06-07-2012 09:30 PM
All times are GMT -7. The time now is 04:47 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
