Originally posted by jake14mw So, in M mode, can I set the SS, set the aperature, and then set the ISO to Auto, and let the camera choose the ISO so that if the lighting changes, it will still expose correctly?
Yes. In M mode, you set the ISO the same way you do for photos. It will only go up to 3200, though. The display of shutter speed, aperture, and ISO will turn red if it can't set an adequate ISO value.
Quote: Have the "program lines" that the K-01 uses in P or AV mode been published anywhere? For example, in P mode, does the camera try to follow the 2x frame rate rule and keep the SS at 2x the frame rate for as long as it can, more freely changing the aperature and ISO?
Don't know.
