Originally posted by peter p When mounting a manual 55mm 1.8 lens on my k-01, the shake reduction appears not to be active. I use an original pentax m42 to pk mount adaptor.
The option to switch on the shake reduction cannot be used in the menu when the manual lens is mounted.
What's the trick to switch the in body sr on?
I should not that pictures do turn out beautifully (color, 3d, bokeh) if shuttertime is sufficiently short.
Thanks for the suggestions. Peter
You gotta type in the focal length at the prompt shown on startup, or go into the menu and type it in manually in the SR tab, I believe.
PentaxForums.com Webmaster (
Site Usage Guide |
Site Help |
My Photography)
PentaxForums.com server and development costs are user-supported. You can help cover these costs by
donating or purchasing one of our
Pentax eBooks. Or, buy your photo gear from our affiliates,
Adorama,
B&H Photo,
KEH, or
Topaz Labs, and get
FREE Marketplace access - click here to see how! Trusted Pentax retailers:
