Originally posted by Crust 3. Focus peaking is on and, even with it on, it's hard to tell if the background or the subject is in focus.
It helps to also magnify the image with the OK button. The e-dial allows you to adjust the amount of magnification.
Quote: 6. How do I adjust the central focus box to the smallest size? I would love to do that!! I tried but couldn't find a way to adjust the size. If anyone could let me know, I would greatly appreciate it.
It wasn't clear from your post whether you are using the Select or Spot autofocus method. With the former, you can use the OK button to display the autofocus area, then the e-dial to change the size and the 4-way controller to change the location. With the latter, it's always a small spot in the center of view.
I've had a few shots where the focus was on the background, but I
think what happened is that I focused by pressing the shutter release half-way, then recomposed the shot before the camera had finished focusing. I can't be sure, since I didn't notice the result until long afterwards, but in each case I was in a hurry, and it hasn't happened since I started being more careful.
