02-12-2013, 02:24 PM   #1
Noob question: Should any K-mount AF lens work on K-01?
I was operating under the assumption that any K-mount AF lens would work (as in AF should work) on the K-01. I mounted a Sigma 75-300mm AF f4.5-5.6 on the K-01, checked that the K-01 focus switch was on AF, and turned on the camera. No matter what (I took the e-dial for a spin), there is no sign of AF working, and the shutter won't activate to take a pic (even unfocussed). The screen just blinks with a red F--
Camera works fine with DA lenses -- I've tried the 40mm xs and 18-55 DA II
Is there some setting in the camera that I need to turn on/off? I don't think there's anything wrong with the lens 'coz it does the same with another Sigma zoom (I forget its specs). I am not looking for fast AF, just some indication of AF.
Thanks for a pointer or two.
02-12-2013, 02:30 PM   #2
The short answer is yes. The long answer is that telephoto lenses (especially consumer zooms) are really slow to focus. Slow to the point where I can't recommend using them in AF mode.
Check your lens's contacts and try cleaning them to see if that fixes the problem. Also, make sure the aperture ring is set to "A".
Adam Webmaster (Site Usage Guide | Site Help | My Photography) server and development costs are user-supported. You can help cover these costs by donating. Or, buy your photo gear from our affiliates, Adorama, B&H Photo, or Topaz Labs, and get FREE Marketplace access - click here to see how! Trusted Pentax retailers:
02-12-2013, 02:51 PM   #3
drei3's Avatar
You should also check to see if it the auto focus works on a different Pentax DSLR. I had a similar issue with an old Sigma AF lens on a K-r. Turns out it the A setting wasn't working properly.
02-12-2013, 03:14 PM   #4
Thank you both. The issue was operator ignorance :-) I saw the A marking by the aperture ring but didn't realize its significance (I did look vainly for a MF-AF toggle) nor that I had to press a nub to get it to click.
The AF is indeed slow but there are occasions when it locks in extremely fast (perhaps when there aren't too many objects confuse it).
af, camera, da, k-01, k-mount, k01, lens, mirrorless, pentax k-01, sigma
IR remote wont work on K-01 slackercruster Pentax K-01 19 02-26-2013 05:59 AM
Will a new K mount lens for a DSLR work on my ME Super? iamtheju Pentax Film SLR Discussion 5 12-27-2012 06:53 AM
Question of focus with a manual lens on a K-01 visual zen Pentax K-01 3 02-18-2012 10:27 AM
Should the K-01 have been a new lens mount? johnmflores Pentax K-01 51 02-10-2012 08:18 PM
k-mount on K-01 question Yassarian Pentax K-01 7 02-06-2012 06:15 PM
All times are GMT -7. The time now is 05:21 AM. | See also:, part of our network of photo forums!
