Originally posted by harioharima A q abt your lens. Are all Super Takumar's m42 mounts?
Yes. Pentax did reuse the 'Takumar' name for a few bargain K-mount lenses that lacked the coatings (an insult to a great name!), but the "Super Takumars" were all M42. There are also older Auto-Takumars and later "Super-Multi-Coat" or "SMC Takumars".
Originally posted by harioharima If so, what's a good mount type for a 50mm f1.4 or 55mm f1.8 m42 lens? From what I read, there appear to be two types - one that permits infinity focus, and one that does not. If I am correct, the latter is much easier to remove from the camera and can be treated as part of the lens. If the lens is mainly for inside/portrait use, would it be reasonable to assume that it's better to get the non-infinity m42 mount?
The genuine Pentax adapter is the one to get if you are getting only one. It's more expensive, but you don't have problems getting it out of the camera. For the more experienced, the cheap 'infinity' adapters work fine with some mods (remove locking spring, maybe clean up bayonet tabs), but it's best to start with the Real Deal. The non-infinity adapters with the flange aren't really worth it, IMHO. They are useful raw materials for hacking other lens mounts, but that's for those with advanced cases of Lens Buying Addiction.
Originally posted by harioharima Also will AF work with these cheapish adapters?
All of these old lenses are manual-focus only.
