01-23-2015, 09:55 AM   #76
OnTheWeb's Avatar
I'm just thinking out loud here but in a pinch couldn't some wiley tech-guys here generate a 3D print model from an original and send it to Amazon and have the little knobs "printed?"
01-24-2015, 09:01 PM   #77
Designosophy's Avatar
Well, I just learned that you can't get mode dials from the source where I got mine anymore.
02-22-2015, 10:19 PM   #78
More on the K01 mode knob problem: I love the K01 so much that I have three of them; the knob has now come off the second one. As I did with the first, I glued it back on using two diametrically opposed spots of superglue. Then I tried to pull the knob off my third K01, it didn't want to come off; I resisted the urge to pry it off with a flat blade. Gluing it back on is easy and seems to work, but the big worry is losing it.
For the moment I'll just keep a knob watch lookout when using K01 #3. It has a later serial number than the other two; the first two had serial nos in the 430xxxx range, while #3 is 4321189. Perhaps Pentax has fixed the problem on later cameras?
02-23-2015, 05:36 AM   #79
PiDicus Rex's Avatar
Interesting,... mine is a 430xxxx too.
I've also found what appears to be a second weakness in the hardware - the mic input socket on mine appears to have developed a dry solder joint, or a crack in it.
02-23-2015, 02:17 PM   #80
My K-01 is 429xxxx
The contact cement I used after my knob fell off has lasted thus far..
03-23-2015, 05:01 PM   #81
I just lost mine. Pentax won't supply the dial alone. They said to send the camera in for repair, which is north of $100 and leaves me without a camera while I wait. Guess I will keep an eye out for a parts camera. Grrrrrrr.....
03-23-2015, 08:19 PM   #82
I haven't used mine since I lost my knob
As was suggested by others, this may be a good job for someone with a 3-D printer, or a small machine shop. If anyone knows someone with a 3-D printer, or a machine shop, I'd be glad to pay for a replacement knob + S&H, assuming there'd be a minimum quantity for an order.
03-25-2015, 06:34 PM   #83
Oh I think it still works fine without the mode dial cap. The LCD indicates which mode is selected.
03-25-2015, 08:48 PM   #84
It works its just not as convenient or as ergonomic.
06-14-2015, 06:10 AM   #85
shiner's Avatar
So, last night I decided to pull K01's out and check the batteries etc, as I haven't used them for a while. Because of this issue I always tug on the dial lightly first thing... popped right off!! Then I picked up my other K01, barely touched the dial, and that one popped off as well! What are the odds? :O
06-18-2015, 01:01 PM   #86
My K-01 is 268xxxx.
QuoteOriginally posted by shiner Quote
The guy at Pentax told me that it's not a common problem for the mode dial to pop off. I wonder how common or uncommon it actually is.
06-18-2015, 07:57 PM   #87
shiner's Avatar
QuoteOriginally posted by Designosophy Quote
My K-01 is 268xxxx.
He may believe that or he's told to say it. Either way, the fact that BOTH of mine gave it up at once defies chance pretty much. I think the adhesive type was a mistake that Pentax is not willing to admit.
06-19-2015, 12:14 PM   #88
It appears to be the only mechanical issue endemic to all K-01's.
(mind you, I've also damaged my Mic in socket, probably from over use or a lead getting jerked on)
Perhaps it's more a matter of all those owners who are likely to report it are also those most likely to be on a forum like this, and thus would have read about it, expected it, and fixed it, without the warranty claims.
06-20-2015, 04:19 AM   #89
This sounds about right, if I hadn't lost mine, I'd have reattached with stronger adhesive, and that likely would have been the end of that......
06-25-2015, 08:15 PM   #90
shiner's Avatar
Mode Dial Measurements
OK, here are some measurements. Also, to my best estimate, from the center of the register hole to the o.d. is ~5.8mm, and 17.2mm to the opposite o.d. The hole is located at the "M" on the dial.
cap, cards, cement, da40xs, dials, fit, k-01, k01, knob, mine, mirrorless, mode, pentax k-01, pin, pop, rubber, screw, service, silver, tech
Pentax K-01 : Problem in video mode with manual lenses minilink Pentax K-01 53 10-28-2013 10:56 AM
K20D Mode Dial Problem ChucK20D Troubleshooting and Beginner Help 6 11-20-2012 07:37 PM
K-5 mode dial physically stuck jaitas Pentax K-5 & K-5 II 4 02-21-2012 04:05 AM
Mode dial problem on K10d Plornt Pentax DSLR Discussion 13 03-16-2011 10:46 PM
k100d mode dial problem song_hm Pentax DSLR Discussion 15 03-14-2011 01:14 AM
All times are GMT -7. The time now is 03:36 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
