02-24-2013, 06:32 PM   #1
Na Horuk's Avatar
Filming
Google didnt give me an answer.. has anyone tried filming with the K-01 for a very long time? Like a video recording going on for an hour and a half without pause? I'm wondering especially about the sensor overheating or the buffer giving up.
02-24-2013, 06:37 PM   #2
Wow, I'm not even going to calculate how big an SD card and battery would you need for that, let alone consider overheating..
02-24-2013, 07:16 PM   #3
The K-01 has a 25 minute (4Gb) limit per file, I believe. You will have to manually pause the recording and start a new file once this limit is reached. The sensor can overheat- with the K-30 I got a temperature warning after about 40 minutes of live view usage.
02-24-2013, 07:19 PM   #4
Na Horuk's Avatar
Great, thanks for the info! I was wondering if the K-01 deals with overheating better than DSLRs, because.. well, its constantly in live view, so they should have considered that.
02-24-2013, 07:38 PM   #5
Banned
I have over twenty combines hours of video with the Pentax K-01. Yes it's all pieced together somewhere and not combined.
But to answer the question in parts...
TheK-01 has zero issues that I'm aware of with any type of sensor burn or overheating. Ironically there is a type of screen warning that would "click-in", but I've never seen it - although it is referred to in the manual.
Also... The K-01 like most other cameras does have a limit as to how much video it can write; depending upon sensor settings, memory card, etc... Under the max resolution settings and using the best possible memory card I believe the max video recording time is a bit less than twenty minutes.
02-26-2013, 03:34 PM   #6
Buffer fills in 16 minutes 23 seconds in full HD mode--if we can believe the timer provided in the lower right corner when actually shooting video. It pops up in place of the "time remaining to fill the card" number that is in that corner when you switch to video mode.
Not so sure that "buffer" is the right term?
07-01-2013, 02:46 PM   #7
RonHendriks1966's Avatar
I have recorded a soccergame in 6 takes from each around 15 minutes. Just stopped and started again with offcourse a 15 minute break. No worry's about overheating.
k-01, k01, mirrorless, pentax k-01
Help with the theory behind filming. Meme Video and Pentax HDSLRs 12 11-05-2012 05:27 AM
Best Pentax camera for filming? Vininski Video and Pentax HDSLRs 11 06-10-2012 07:24 AM
setting the ISO when filming in full HD chrismaris Pentax K-5 3 11-12-2011 04:23 PM
Best Pentax Filming Zoom Lens bentley321 Pentax SLR Lens Discussion 4 08-15-2011 04:04 AM
What is good wide lens for filming? vanakaru Video and Pentax HDSLRs 9 03-21-2011 12:08 PM
All times are GMT -7. The time now is 03:34 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
