03-01-2013, 11:36 PM   #1
Occasion jagged image
Two or three times now I've taken shots which, when replayed, were extremely jagged and pixelated - way out of the norm. None of the shots were salvageable. Anyone else experience this? Am I taking a shot too quickly after turning the camera on? Using an SD card thats too slow? Something else?
03-01-2013, 11:44 PM   #2
Anvh's Avatar
You will notice that the camera keeps on if it's busy, even when you turn it off so that isnt the problem.
Do you have an example?
03-02-2013, 03:49 AM   #3
It happened to me with certain low speed SD cards, a firmware upgrade fixed it, Have you updated yours beyond v1.0?
03-02-2013, 04:53 AM   #4
It sounds similar to the images I got from my old Nikon D70 when I was using a corrupted memory card. If the firmware update doesn't fix it then you might have a bad memory card.
03-02-2013, 05:37 AM   #5
I just upgraded to 1.03 so it's not due to aging firmware.
Thanks for the tip about the card. I'll keep an eye on it. Right now I'm using a Transcend 32GB class 10. I have another card coming in the mail from a different manufacturer so I can see if that makes a difference.
03-02-2013, 06:16 AM   #6
Hopefully it is just a corrupted memory card and not something wrong with your camera.
I've had bad memory cards (CF and SD) from Lexar, Sandisk, Kingston, Transcend and A-DATA ... but never more than one bad card from any of those manufacturers. Thankfully, the price of memory cards had come down so low that it's not a huge problem to replace one when it goes bad.
I just look at corrupt memory cards like a bad roll of film back in my film days. Sooner or later everyone runs into a bad one and you just get rid of it and move on ... and hope that a once-in-a-lifetime moment was lost because of the bad film/card.
03-02-2013, 07:36 AM   #7
robtcorl's Avatar
I had this happen recently with a brand new Sony 16GB card, had to return it.
Transcend cards have all worked perfectly for me though.
03-04-2013, 08:27 PM   #8
This morning, I notice the jagged appearance on the screen when I turned the camera on. The jaggedness went away after I cycled the power. This occurred with the new card so it's not likely the card.
I'll continue to post as I make more observations.
03-05-2013, 06:33 PM   #9
I may have a doomed K-01. Now it's making a hissing noise from the lens side of the camera. No more jagged images though.
k-01, k01, mirrorless, pentax k-01, shots
inside a lens, jagged rainbow nmrecording Troubleshooting and Beginner Help 4 10-23-2012 08:01 AM
Resizing image in photoshop without changing the original image quality LFLee Digital Processing, Software, and Printing 14 09-25-2011 05:18 PM
K-5 fine lines become jagged Sten Pentax K-5 7 02-21-2011 12:33 AM
FA 50mm f1.4 jagged aperture - is this normal? PolishMike Pentax SLR Lens Discussion 12 06-25-2009 07:06 PM
Jagged edges? FunkyMonk Pentax DSLR Discussion 7 01-23-2009 01:50 PM
All times are GMT -7. The time now is 11:44 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
