03-14-2013, 04:45 PM   #16
RonHendriks1966's Avatar
For the DA21mm:
http://www.pentax.de/media/011a067735b62e7c2b87f04440523cc4/Datenblatt_smc_P...AL_limited.pdf
For the 15mm:
http://www.pentax.de/media/d5572838c113c738c55e448958dde6d6/Datenblatt_15mm.pdf
I would prefer the 21mmmyself.
03-14-2013, 04:45 PM   #17
twitch's Avatar
LR4 fixes distortion and more importantly for the DA12-24, CA & PF. The 12-24 has less distortion than the DA21 and about teh same as the 15. It is a very sharp zoom and has a versatile range. The only downside is size/weight compared to the primes.
03-14-2013, 07:41 PM   #18
perpetual3 -- I have a DA 16-45 zoom lens, and use it everyday. 24 to 67 equivalent. If I could take only one lens on a trip, this would be it... at twilight or evening, I can always bump the ISO a bit to compensate for it being f/4 instead of the DA-21's f/3.2. The DA 16-45 gives you a very useful range -- from quite wide-angle to mild telephoto -- that should make for a perfect vacation!
03-25-2013, 10:52 AM   #19
After spending the last four days shooting around Los Angeles, I'm even more sure of the 21. Even though I loved the IQ of the k01 with the 40xs, I just couldn't get used the fov.
Went back to using the grd4 and the 28mm fov simply works. Sometimes I want a little bit tighter, sometimes wider, but the 40xs is just to much. I'll continue using it for portraits. But otherwise, I can't use it a my general lens.
On the plus side, I figured out a quick way to dial in zone focus using focus peaking.
da21ltd, k-01, k01, lenses, mirrorless, pentax k-01
Contest Raw fragility - the Duplo DA21ltd give away contest Duplo Mini-Challenges, Games, and Photo Stories 138 06-20-2012 09:07 PM
Wanted - Acquired: DA70ltd, FA43ltd, DA21ltd and/or DA15ltd ASa Sold Items 2 06-17-2012 11:38 PM
da15ltd exposure comp? everydaylife Pentax SLR Lens Discussion 11 05-03-2012 05:10 PM
Landscape Wreta Inn, Sweden with DA15ltd Douglas_of_Sweden Post Your Photos! 16 10-13-2009 11:20 AM
ACR 3.7 v. Silkypix v. Pentax Photolab Richard Day Pentax DSLR Discussion 21 02-22-2007 08:48 AM
All times are GMT -7. The time now is 10:38 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
