03-19-2013, 07:42 AM   #1
jessecad's Avatar
Computer fails to read SD card..
I have many pictures on a Lexar Professional 128gb card which I have used several times in the K7, K5 and I am using it now in the K-01 - shooting RAW. Before using the card in the K-01 I formatted it in the K-01.
I have put the card in the computer several times before to transfer files and for the first time the computer displayed a message "in order to use this card it first must be formatted".
After a few times of this I put the card back in the K-01, viewed all the images (they were all fine), then decided to take another shot, I viewed the image in the camera, then put the SD card back in the computer and now the computer sees the files (Windows 8). I just thought I would pass this info on in case it ever happens to someone else. I have FW 1.03 in K-01
03-19-2013, 08:04 AM   #2
The only time I experienced a similar problem my card reader was going bad. From what I will never know because I just use those 99 cent USB sized ones until they die and throw them away.
03-19-2013, 08:48 AM   #3
jatrax's Avatar
Happens occasionally if the reader is a little sloppy. The card is just misaligned enough to not be recognized so the driver asks to format it. I have seen this several times, take the card out and re-insert and all is good. If it happens more than rarely I would be looking for a new reader though.
03-19-2013, 09:05 AM   #4
Usually it is card reader problem, buy a new card reader and test it. Hope this helps....
03-19-2013, 12:03 PM   #5
THoog's Avatar
I had this happen with one card, and under close inspection found that the little plastic ridge between two of the contacts had split off. On my PC and laptop, the sliver of plastic would get pushed over and block the contact, but never with my camera. I trimmed off the sliver and have had no problems since.
card, computer, files, k-01, k01, mirrorless, pentax k-01, sd, times
SD Card won't Read/Write in Camera bobell69 Troubleshooting and Beginner Help 3 02-05-2013 08:52 PM
K10 can't read SD card saladfunky Troubleshooting and Beginner Help 2 07-19-2011 01:54 PM
Crap! My new class 10 sd card run much slower than my old class 4 sd card... liukaitc Pentax Camera and Field Accessories 15 05-31-2011 01:39 PM
My computer won't read my memory card Pål Jensen Pentax Camera and Field Accessories 7 07-29-2009 11:32 AM
All times are GMT -7. The time now is 03:50 PM. | See also:, part of our network of photo forums!
