03-20-2013, 03:45 PM   #1
AF Slipping
Just to pass it on in case it happens to you. A couple weeks ago, the AF on my K-01 went dead. When I focussed, all that happens is that I heard a bzzzzzzzzzz bzzzzzz bzzzzzzzzzzz sound, but nothing else. Removed the lens, put it back on, no change. Tried different lens, no change. Last... thinking ...darn, something gone bad on me, I switched to MF and back to AF, .... all was well again.
What happened, the AF switch was accidently ever so little pushed toward the MF side, enough to disengage the mechanical coupling, but not enough to turn OFF the AF function.
So beware if/when this happens to you.
03-20-2013, 04:14 PM   #2
wlachan's Avatar
This has never happened to any of my Pentax cameras for the last 2 decades. Perhaps the switch is a little loose inside?
03-20-2013, 04:40 PM   #3
VisualDarkness's Avatar
I've done it a couple of times with my K-5 as I sometimes don't seem to push the lever all the way, now I know what it is instantaneously though.
af, change, k-01, k01, lens, mf, mirrorless, pentax k-01
FA 43mm f1.9 Ltd - Focus ring "slipping" problem Schuler Pentax SLR Lens Discussion 7 03-10-2012 02:35 PM
Macro I'm slipping! eaglem Post Your Photos! 0 03-09-2011 04:43 PM
Slippage/Slipping on FOCUS ring? 50mm SMC 1.7 PentaxForums-User Pentax SLR Lens Discussion 4 03-08-2009 09:55 AM
Slipping Manfrotto 679B monopod gawan Pentax Camera and Field Accessories 6 09-05-2008 11:34 AM
slipping on monopod base rmtagg Photographic Technique 2 05-01-2008 07:36 PM
All times are GMT -7. The time now is 09:26 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
