03-22-2013, 02:04 PM   #1
tdmsu's Avatar
Strange HDR artifact
While shooting the Spirit of Detroit today, I decided to try out the HDR function, and it seems to have amplified the chromatic aberration (if that's what the purple is) as well as the rest of the image. It's strange to me because it was not a sunny day, and I was facing east in the early afternoon. I like the way the gold pops, and I kind of like the purple, too because is appears to be peaking between the statue's fingers.
What do you think?
PENTAX K-01  Photo
03-22-2013, 02:20 PM   #2
joe.penn's Avatar
QuoteOriginally posted by tdmsu Quote
What do you think?
Post the pic...
03-22-2013, 02:43 PM   #3
tdmsu's Avatar
Internet hiccup - thanks for the snark, though.
03-22-2013, 02:53 PM - 1 Like   #4
panoguy's Avatar
That's just the Spirit of Detroit made visible! Looks pretty good, even if unintentional...
03-22-2013, 03:27 PM - 1 Like   #5
Ole
Ole's Avatar
Light from behind you hitting the gold, then reflecting through the fingers. Diffraction caused by the small opening between the fingers smears the effect.
Perhaps there also is a reflection from the sensor back to the lens's rear element and then back onto the sensor again. Hard to say.
03-22-2013, 03:40 PM   #6
Anvh's Avatar
looks like ghosting, i believe the sun was in the trees or not?
03-23-2013, 05:38 AM   #7
Did you have a 'protection filter on? If so remove it and the effect will disappear or at least reduce.
Flare is caused by bright highlights internally reflecting within the lens, in this case probably originating from the bright gold statue. Normally these reflections bounce out of the lens and away, but the flat surface of a filter acts like a screen and reflects them strait back into the lens again (and again, and again) recording onto the sensor every time which makes any flare much more pronounced.
The clue is in the colour of the flare, blue is the reciprocal of yellow, which would be the original colour of the highlight if it came from the gold statue. The HDR processing would exaggerate this.
Chris
03-23-2013, 07:02 AM   #8
tdmsu's Avatar
I did not have a filter on the lens, but light reflecting sounds good. The same artifact appears on another HDR of the same statue, so now I'm wondering more. I'll attach two photos from the same day, both HDR. One has the purple artifact, the other is a wider shot to show the weather conditions, and I don't see the purple on that one.
I have not noticed this artifact on non HDR shots, or on other subjects...
PENTAX K-01  Photo
hdr, k-01, k01, mirrorless, pentax k-01
K5 HDR Artifact stoge Pentax K-5 3 07-11-2011 03:24 AM
Black & White Ape skull - museum artifact Gareth Post Your Photos! 13 06-15-2011 01:06 PM
Help with processing artifact: Rodinal/stand dev Todd Adamson Film Processing, Scanning, and Darkroom 13 04-11-2011 12:52 AM
Image artifact madphys Pentax DSLR Discussion 20 01-03-2009 08:03 PM
artifact correction via photoshop gpaual Digital Processing, Software, and Printing 2 01-07-2008 08:44 PM
All times are GMT -7. The time now is 12:25 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
