04-03-2013, 01:00 AM   #1
Red marks -- 10 3 ???
My old Pentax-A f/2.8 28mm lens has a red '10' and '3' next to the infinity mark on the distance scale. For feet and meters. Got that. But why are these numbers in red, not blue and yellow like the other distance numbers?
And, if I line up the red 10-and-3 with the red diamond on the fixed aperture scale... what does that mean? See pic below. Is it a quick way to get hyperfocal... for everything? Or, does it mean something else?
04-03-2013, 01:32 AM   #2
Cheap Chinese UV filter ruining all that PENTAX optical goodness! Shame on you Jon, shame!..
Is this the same lens?
SMC Pentax-A 28mm f/2.8
SMC Pentax-M 28mm F2.8 Reviews - M Prime Lenses - Pentax Lens Reviews & Lens Database
04-03-2013, 01:33 AM   #3
hcc
hcc's Avatar
I do not know for the red 10 and 3, but the 'red diamond' is in fact with a 'red arrow' with line up wit the Green A when you set the lens to Automatic Aperture (A).
Hope that the comment may help.
04-03-2013, 01:54 AM   #4
@Sledger -- I want to have a clear filter over the lens, because I carry the camera around without a lens cap. Recommendations? And yes, it's the same one as on Ken Rockwell... an A-type... apparently the same as an M but with the A setting.
@hcc -- thanks... yes, the red arrow it does line up with the green A, as in the photo above. I keep the lens on A all the time. But I'm curious about the red '10 and 3'. Why would Pentax mark these numbers in red?
04-03-2013, 02:22 AM   #5
Chris Stearns's Avatar
The smallest red mark is used for shifting focus when shooting infrared. The red diamond is the focus point. The 10 and 3 as well as f8 are red because thats the implied best setting that will make everything from 5 feet to infinity in focus. Hope that helps!
and I would consider buying a metal lens hood in place of the cheap filter.
04-03-2013, 04:30 AM   #6
QuoteOriginally posted by jon404 Quote
Like Chris, I suggest a lens hood.
04-03-2013, 05:39 AM - 1 Like   #7
THoog's Avatar
The red/orange "10 3" are the hyperfocal distance for f/8 (also orange). A lot of the Pentax wider primes have the f/8 hyperfocal distance marked this way, going back to the Takumars. The orange line just to the left of the diamond is the infrared focusing mark. Since the hyperfocal distance was calculated for 35mm, for APS-C some people go one f-stop higher; I like to crank the lens a little to the right. That makes everything from 7 feet to infinity "acceptably sharp".
04-03-2013, 04:20 PM   #8
Thanks all -- will check out metal lens hoods, and -- Thoog -- what a perfect explanation. You know, if I was a reporter with an APS-C Pentax, I might just leave it on 10-3 f/8 (or f/11) for anything reasonably close, and at infinity for far away. Or at your setting for whatever comes along!
distance, k-01, k01, mirrorless, pentax k-01
Optio WG-3 GPS, WG-3, and WG-10 Outdoor Compacts officially Announced Adam Pentax News and Rumors 13 02-03-2013 03:02 AM
Project 52 Project 52 - 4 - 10 Colour - Red - WINNER Graham V Weekly Photo Challenges 13 12-15-2011 06:52 AM
Red Scratch marks? BlueEyes Troubleshooting and Beginner Help 3 11-29-2009 06:33 PM
Red marks on SMCP-M 1:2.8 28mm MrEspie Pentax SLR Lens Discussion 2 05-02-2009 09:03 PM
What are these red marks in the leaves, K10D? WildSioux Photographic Technique 29 06-23-2007 12:35 PM
All times are GMT -7. The time now is 07:44 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
