11-07-2014, 11:23 AM   #181
QuoteOriginally posted by Pentaxaholic Quote
Can anyone provide a link to information about this viewfinder?
I don't know if this is the style of viewfinder Dabber is referring to, but...
http://www.amazon.com/gp/product/B0084LFED0/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
A number of companies market the same/similar device.
I use it for tele work, because it allows me to have increased stability by allowing DSLR-esque technique... and of course it also blocks the sun's light.
11-07-2014, 07:57 PM   #182
QuoteOriginally posted by luftfluss Quote
Amazon.com: NeewerŪ 2.8x 3:2 DSLR LCD Screen Viewfinder Extender for Canon EOS Rebel T3i/600D and 60D: Everything Else
Thanks for sharing! I'll have to do some more research to see what fits the K01!
I started using my K01 for Astro photography! Up high on my tripod, I can see lcd just fine!
I wouldn't mind having one of these viewfinders for macro work or sunny days!
11-08-2014, 01:02 AM   #183
Resident fiddler
LensBeginner's Avatar
How do you do that without astrotracing support? a dedicated motorized mount?
11-08-2014, 05:35 AM   #184
That is one, of course. But I don't know anything about it. You can see the Swivi viewfinder I mentioned at: cheesycam.com/new-gear-swivi-lcd-view-finder. That, too, is available from Amazon!
Or you can go to this thread on the Pentax Forum: Finding a thumbscrew is torture! (pun intended) under the K3 threads because I couldn't find the one I wanted !
ADDED: If I understand what DSLR-esque technique is, that is one advantage, but I believe that the main thing about viewfinders of this type is that they let you see the LCD when taking pictures in bright sunlight with the sun behind you by screening the sun which would otherwise make the image on the LCD impossible to see.
One thing I have just thought of is that the length of the viewfinder means your face is further away from the camera than with a viewfinder as part of the camera, so you don't have to turn your head sideways to keep your nose out of the way! I'm not being too serious about that additional advantage.
11-08-2014, 07:17 AM   #185
Mikesul's Avatar
I have debated getting something like the Swivi but wouldn't that make the camera unwieldy handheld?
11-08-2014, 08:29 AM   #186
QuoteOriginally posted by LensBeginner Quote
No, just use online programs to locate what I want to set up for and use it like a normal camera, but with focus peaking to see better. For example: I can't seem to lock focus onto Polaris to do star trails. I'll find it, then focus peak until I have it centered, then shoot. No worries about sun glaring on lcd in the dark!
---------- Post added 11-08-14 at 09:30 AM ----------
QuoteOriginally posted by Dabber Quote
Thanks!
11-08-2014, 08:34 AM   #187
Resident fiddler
I was talking about star movement... either you have a short focal, luminous lens or you have to raise the ISOs in order to keep shutter speeds fast enough to avoid star trails...
If you're shooting star trails in the first place then no problem!
11-08-2014, 09:01 AM   #188
Shooting mostly star trails.
---------- Post added 11-08-14 at 10:01 AM ----------
11-08-2014, 09:34 AM   #189
I had considered that particular Swivi, but a) its expensive and b) its not easily and quickly removable in the field. The one I linked to has a thin metal frame that adheres to the LCD panel, and the loupe attaches to it via magnets. Since I generally only use the device for tele work and some macro, its more convenience for me not to have it almost permanently attached.
11-08-2014, 09:45 AM   #190
Mikesul's Avatar
I have successfully used a ClearViewer that I had purchased for the Q (they are made to order). It did not give me the whole LCD but enough for stable manual focus handheld in bright light. That was good enough for me.
11-08-2014, 10:19 AM   #191
luftfluss said:
"I had considered that particular Swivi, but a) its expensive and b) its not easily and quickly removable in the field."
(A) No, it's not cheap, but worth every penny/cent.
B) The trick is to leave the baseplate permanently attached to the camera. To release the viewfinder "hood" you loosen a small thumbscrew at the side of the baseplate which frees the tab or "tongue", releasing the viewfinder "hood". This can then go in your camera bag or wherever. Don't forget to tighten the thumbscrew so that it doesn't drop off.
---------- Post added 11-08-14 at 05:27 PM ----------
No. My K-01 is about twice as heavy as the Swivi viewfinder. So you're not adding all that much. Now, add a sturdy tripod and you know you've added extra weight.
I don't know if this makes sense, but I understand that Steadicams - the thing that makes film and TV cameras steady - works on the principal of a weight at the bottom of the unit (as well as being attached to a bar connected to the cameraman's belt). So do you want to put up with extra weight or have just a light camera that it shakes all over the place? !
11-08-2014, 10:28 AM   #192
Yeah, that's the thing... I'm a ramblin' man, I wear the loupe on a lanyard around my neck, place it on the LCD when needed - literally takes one second - and simply pull it away when done. I also should mention that since I wear eyeglasses, the particular EVF viewer I use has a large, soft eyecup that fits over the left lens/frame, which is a big plus for me. One of the EVF viewers I tried didn't do that.
Anyway, I think some kind of EVF viewer is pretty much essential to have if you own a K-01.
11-08-2014, 10:33 AM   #193
Mikesul's Avatar
I want small size and light weight. If that is not an issue I use my k3.
luftfluss said: "I had considered that particular Swivi, but a) its expensive and b) its not easily and quickly removable in the field."
Read more at: https://www.pentaxforums.com/forums/138-pentax-k-01/221202-k-01-very-misunder...#ixzz3IUwknMpQ
11-08-2014, 10:46 AM   #194
Resident fiddler
*snip*
Yeah, I kinda remember the "wherever" bit!
11-08-2014, 11:28 AM   #195
Yeah, yeah !
For those who don't understand this and the previous post:
https://www.pentaxforums.com/forums/172-pentax-k-3/277961-finding-thumbscrew-torture.html
aps, camera, cameras, da, ir, k-01, k-1, k01, lens, lenses, liveview, mirror, mirrorless, pentax, pentax k-01, picture, plastic, pm, post, quality, sensors, size, sony, spec, viewfinder, window
Very very cheap K-01 jena Pentax K-01 7 03-28-2013 04:44 PM
Pentax K-01 Oz stock A$299.95 from Ted's Camera raider Pentax Price Watch 14 12-10-2012 06:18 PM
K-01 as a backup camera ? Please help me decide ! Matchete Pentax K-01 11 07-07-2012 05:57 AM
Be VERY Careful looking for K-01 bargains Docrwm Pentax K-01 7 03-14-2012 11:28 AM
Very, Very, Very Large Format Camera Available shutterdrone General Talk 22 03-22-2008 10:43 AM
All times are GMT -7. The time now is 04:30 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
