04-10-2013, 05:35 AM   #1
Overexposed shots using M-50mm 1.4... need help.
Hello!
I am enjoying my K-01 had it since December and am seriously thinking about branching out my little home business into producing short business videos like this one I recently made.
http://youtu.be/QlcU3K9_TS4
Apart from me being cinematography-challenged overall, I often have a problem with overexposed shots especially when using my Pentax M 50mm 1.4. I focus the shot and it looks okay so I start shooting but ten seconds in, the shot gets to washed out and ruins the shot. You can see a lot of this happen in that and my other videos.
Anyone experience this and can you share some tips?
Thanks!
04-10-2013, 05:52 AM   #2
Tom S.'s Avatar
Your link doesn't seem to work.
04-10-2013, 05:54 AM   #3
Jean Poitiers's Avatar
QuoteOriginally posted by Tom S. Quote
Same here ... no link ... J
04-10-2013, 05:59 AM   #4
Sorry about that
here's the URL
04-10-2013, 06:28 AM   #5
sterretje's Avatar
Copy and paste: http://youtu.be/QlcU3K9_TS4
04-10-2013, 06:57 PM   #6
FWIW, I also experienced overexposure problems using the M 50mm 1.4. Since that, I just use the "half-cock lens method" -- basically when mounting, you screw the M lens halfway to prevent the aperture lever from engaging.
04-10-2013, 08:07 PM   #7
mine is k-mount though.
04-10-2013, 08:21 PM   #8
QuoteOriginally posted by johncarlgalang Quote
Yes, it is for k-mount lenses. Just mount the lens stopping just about before the locking pin engages.
Note: Without the lock engaged, check that there's enough friction so the lens wont come loose when in use.
04-10-2013, 09:10 PM   #9
QuoteOriginally posted by Salagubang Quote
thanks for the tip will give that a try
04-11-2013, 01:32 AM   #10
Are you shooting in M mode and using the green button to meter? It looks like the camera is making adjustments, probably ISO, after shooting begins. I don't think P mode will work with M lenses if that's what you're doing. The manual says exposure error may occur in Av mode as well.
You might try taking it off auto-ISO as well so the camera only sets the shutter speed.
05-11-2013, 10:14 PM   #11
I think I've finally found the solution to this...
I set the AE Metering to Center-Weighted a couple of days ago and it seems that I don't experience this anymore.
business, k-01, k01, mirrorless, pentax k-01, shot, shots, videos
Shutter fires when using 50mm 1.4 Pentax M on KR gridzero85 Troubleshooting and Beginner Help 7 09-25-2012 05:53 PM
For Sale - Sold: K5 + sigma 30mm 1.4 + tamron 17-50mm 2.8 + pentax M 50mm 1.7 ueda_masaki Sold Items 5 09-25-2012 12:09 PM
I need some serious help fixing an overexposed photo hambone Pentax K-5 38 01-25-2012 10:59 AM
Help me with my S-M-C TAK 50mm 1.4 issue alanpierrotcine Troubleshooting and Beginner Help 17 05-27-2011 10:37 PM
Help!! Need best generic lens hood for FA 50mm f/1.4 CaymanImaging Pentax SLR Lens Discussion 12 02-20-2009 10:36 AM
All times are GMT -7. The time now is 12:41 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
