04-15-2013, 07:06 PM   #1
AF autozoom possible with manual lens ?
Is it possible to get the screen to zoom up with the old manual lenses ? Works fine with my auto focus lenses but what I really want it for is to use autozoom together with focus peaking for my manual focus lenses. The screen is not accurate enough as-is with my 50 @ f1.4
Also is there a way to just default the lens length so I don't have to hit the OK button every time I start the camera with a manual lens attached ?
Thanks Tim
04-16-2013, 12:26 AM   #2
hks_kansei's Avatar
I'm not certain what you're asking here.
Are you asking if, when using liveview, the screen will zoom as the lens is zoomed in/out?
If so, yes, liveview is just showing you what the sensor is seeing, zooming the lens in will mean the image projected by the lens is more magnified. (no different to how you can see the image zoom in/out through the viewfinder)
04-16-2013, 01:36 AM   #3
If autozoom is activated in menu, pressing the OK button gives you zoom with manual focus lenses as you know. The e-Dial will give you switchable 2X or 4X zoom.
With focus peaking on I find that if you swing the focus ring it just 'pops' into focus, like it did when using the old fresnel lenses on some SLR cameras. I don't use focus zoom much.
Chris
04-16-2013, 08:18 AM   #4
Ah didn't know about pushing the OK button to zoom the screen, just got the camera and the seller is still looking for the manual. @ f1.4 I wasn't finding the normal screen accurate enough for placing focus now with the screen zoomed 4x I can get it exact.
Thank you.
QuoteOriginally posted by ChrisJ Quote
Chris
autozoom, focus, k-01, k01, lens, lenses, mirrorless, pentax k-01, screen
Linear Polarizer in Manual with manual lens Den Photographic Technique 8 12-19-2012 11:10 PM
Possible problem with manual lens on KR chaza01 Pentax DSLR Discussion 17 04-30-2012 03:18 PM
AF adjustment setting with manual lenses zman Pentax DSLR Discussion 2 10-19-2011 06:25 PM
kx photo with 55-300mm lens af works,but as a newbe to manual focus litboat Troubleshooting and Beginner Help 4 11-07-2010 05:04 PM
Is it possible to improve AF with screw driven lenses? button Pentax SLR Lens Discussion 5 12-18-2007 06:47 PM
All times are GMT -7. The time now is 09:55 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
