04-16-2013, 08:50 AM   #16
audiobomber's Avatar
Probably not!
I think we all want to experiment with all these different paradigm cameras (Q, K-01, GRD) and I beleive we are finding that they aren't generalist cameras - they're specialty cameras. They're actually each intended for a specific subset of users. The dSLR is our generalist camera,
I recently received a K-01 and ordered a Q with 01 prime. Yesterday I received a Carry-Speed VF-3 which I am intending to return. I think I'll be happier using the Q and K-01 for their primary uses, forget about esoteric pursuits. I expect the K-3 will be the best tool for super tele, hopefully with a new Pentax TC.
Kenafein, those shots do look good.
04-16-2013, 09:08 AM   #17
Na Horuk's Avatar
QuoteOriginally posted by audiobomber Quote
The FA 35mm is not ultra-wide or slow. I used the DA*300 with and without TC and focus was soft in either case.
Yeah, I explained the problem in the rest of the post. The camera stops the lens down and thus the DoF in peaking is bigger than in the photo. Out of fairness I also mentioned lenses which will work poorly with peaking no matter what. As i said, you can try taking photos at even smaller aperture/wider DoF, if the scene allows. Then again, if you know that FP is backfocusing for you, you can try putting it just in front of the subject.
04-16-2013, 09:17 AM   #18
I tested the FA 35 f2 wide open, the DA*300 was used wide open and at f5.6.
I've used FP with AF active, to confirm that focus was where I wanted. It appears to be accurate, but too coarse in some situations.
04-16-2013, 10:27 AM   #19
Na Horuk's Avatar
Yes, but its only wide open when it takes the photo, not necessarily during live view, when it also peaks the focus.
04-16-2013, 10:48 AM   #20
I don't think that is correct. It stops down to the selected aperture when it takes the photo, otherwise it's wide open.
04-16-2013, 10:49 AM   #21
I have to say, with M and K lenses, the focus peaking much better (as they are not stopped down)
04-16-2013, 10:49 AM   #22
mrNewt's Avatar
Yep, pretty much... unless is a manual lens.
04-16-2013, 10:53 AM   #23
The K-01 stops down somewhat in bright light. (This is easy to see, just sit indoors next a window with bright daylight outside and turn the camera back and forth from the bright window to the darker indoor room -- you'll hear it (and see it if you look through the front of the lens without blocking the light) clicking back and forth as it opens and closes the aperture. BUT it will stay wide-open during magnified focus-assist. I don't think focus peaking forces it to stay open though...
04-16-2013, 10:58 AM   #24
mrNewt's Avatar
That's actually interesting ... didn't noticed it.
I have to try it now ... hmmm ...
In my defence though I am using manual lenses and it stays at whatever is set.
04-16-2013, 11:01 AM   #25
JinDesu's Avatar
Can we make it do focus peaking AND magnified focus assist? I just recently ordered a K-01, so I'm interested in learning how to set it to do so.
04-16-2013, 11:04 AM   #26
mrNewt's Avatar
Yes, just press on OK for magnification.
04-16-2013, 11:15 AM   #27
JinDesu's Avatar
QuoteOriginally posted by mrNewt Quote
Thanks! So maybe if OP can try using magnification in addition to the focus peaking and let us know how it goes...
04-16-2013, 11:23 AM   #28
mrNewt's Avatar
QuoteOriginally posted by JinDesu Quote
Np! You can even setup the amount of magnification you can have.
Can`t remember if you need to activate it first though...
04-16-2013, 11:51 AM   #29
It does seem really strange that it would stop down the lens during focus peaking mode. That really defeats the purpose, and the camera needs that info to make it's own focusing determination. Is the K-01 the only K camera that you have left? If you can afford the DA* 300 then the painful part is over. Even a used K-r should give you some great shots. (Assuming the AF on the K-01 isnt fast enough. It was with my DA55-300).
04-16-2013, 11:51 AM   #30
Na Horuk's Avatar
The way I have it set up is that I have red button set to turn focus peaking on/off and then sometimes also use the digital zoom. But you need to start peaking before you hit the digital zoom, you can't toggle peaking during the digital zoom. And I think that digital zoom does, in fact, change aperture, which makes it very useful.
And the camera stopping down during regular live view, regardless of peaking, is well documented. There are a lot of threads and posts about this. I thought by now most of you knew. I read that it also happens with the K-30.
af, focus, fp, k-01, k01, mirrorless, pentax k-01, shot, shots, tc, test
focus peaking edgedemon Pentax K-30 & K-50 16 02-10-2013 02:43 PM
Difference between focus-peaking and focus-assist DaveInPA Pentax Q 3 02-10-2013 09:39 AM
Focus peaking dc1500 Pentax Q 4 11-09-2012 08:07 AM
focus peaking dceric Pentax K-30 & K-50 3 07-13-2012 07:25 PM
focus peaking yipchunyu Pentax K-01 3 04-07-2012 09:50 AM
All times are GMT -7. The time now is 07:50 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
