Originally posted by anthony mazzeri Edit - I've just tried adjusting the Aperture ring on the lens away from A so it shows F-- on the screen, in which case the EV button acts as a DOF-preview button instead.
Hmmm, I have my camera set up to use the aperture set on the lens ring. In the menu I have set
Custom 3 > 16. Using Aperture Ring > 2 Enable.
Then I've customized the green button for Tv Shift as follows:
Rec. Mode 3 > Button Customization > Green Button > Action in M/TAv Mode > Tv Shift.
Try that and see if it helps and if it's what you want; of course it's completely reversible if it's not.
