05-09-2013, 08:17 AM   #1
High levels of audible noise when recording video
There is a problem - when recording video appeared background noise in the audio track. Previously, it was not so. Tried to change the firmware, reset the settings - it is useless. What could be wrong?
05-09-2013, 08:51 AM   #2
Ash
Community Manager
Ash's Avatar
Are you referring to a mechanical grinding sound churning at about 5 times a second in the background? If so, it is probably the SR mechanism responsible. Which camera is it? If its a bother to you, switch SR off in video mode and try recording again.
05-09-2013, 08:57 AM   #3
Anvh's Avatar
Well it's posted inside the K-01 forum
As far as i know the SR on that version is software based so it can't be the SR.
05-09-2013, 09:23 AM   #4
This is not the SR. The noise of the other. Also, I tried to disconnect SR. There is no difference.
05-09-2013, 09:33 AM   #5
Here's a sample.
05-09-2013, 10:30 AM   #6
MD Optofonik's Avatar
I'd like to help but I can find no published audio specs for your camera. It's not even listed on the Pentax site anymore so I can't even ascertain whether or not the camera has a mic/line input. With so little info all I can surmise is that the audio specs are well below most consumer grade standards; it simply sounds like the camera has a very poor s/n ratio. If you have a mic/line input I would suggest taking your camera to a music store and auditioning several mics. Heck even a cheap Sony ECM-MS907 might be better than the on-board mic.
There is a solution if you don't have a mic input on the camera, however. The bad news is, it's not very simple. The good news is, you have total control over your audio quality and can upgrade that quality whenever you like. The other good news is, dual system recording isn't nearly as difficult for consumers to pull off as it was even just a few years ago. The other bad news is, dual system recording isn't very "point and shoot" but with practice you can learn to be quick.
If you're in SoCal you might be able to talk me into a one-on-one all day field recording workshop for a reasonable rate, lunch included of course.
05-09-2013, 06:32 PM   #7
Thanks for the detailed answer. But I want to draw your attention to: the noise was not there before. He has recently appeared suddenly. And it's too strong to be "very poor s/n ratio".
05-09-2013, 09:49 PM   #8
QuoteOriginally posted by itscool Quote
It is, clearly, a signal to noise ratio problem; there's just not enough info to say where the s/n ratio fell apart.
I may regret this but provide detailed info about your capture workflow. Everything.
05-13-2013, 04:33 AM   #9
MD Optofonik, thank you for your response
05-13-2013, 06:27 AM   #10
Check your gain settings
I feel It is just bad s/n ratio, picking up ambient sounds.
Check to see you haven't accidentally increased the volume (gain) to full level in the info panel.
The in-camera mics and external mics are controlled independently, btw. You can have the either at any setting and the camera remembers those settings when you plug or unplug.
Also the K-01 shake reduction is done digitally during video recording, so that explains why it made no difference when turned off.
AB
05-13-2013, 06:48 AM   #11
The audio on the K-01 (for lack of a better word) blows. It is very noisy.... and, of course, more noticeable in quieter situations. We use our K-01s professionally for broadcast purposes, but usually record audio on a separate recorder. I have plugged a wireless mic directly into the K-01 with useful results, but EQ is needed to get rid of the "hiss" created by the camera.
05-15-2013, 01:18 AM   #12
Soon I will come another k-01. I'll try to compare. I will write results
05-15-2013, 03:21 PM   #13
Transit's Avatar
All the answers miss the point that the OP said it had got a lot worse.
05-15-2013, 05:14 PM   #14
QuoteOriginally posted by Anvh Quote
Are you sure? Because I'm not.
My understanding is that uses the sensor-shift system.
PENTAX site implies this too
Pentax K-01 - Digital Mirrorless - PENTAX Photo
Attachment 172320
05-16-2013, 05:48 AM   #15
QuoteOriginally posted by Transit Quote
Well, I did actually ask if he had accidentally turned up the gain, which is a possible explanation for it getting worse.
He didn't answer, so he mustn't have!
AB
k-01, k01, mirrorless, noise, pentax k-01, video
Odd noise when shooting video-K5 Pentax Kid Pentax K-5 3 02-11-2011 07:19 PM
K-7 audible noise (clicking) while zooming in or out Jimmymack Pentax DSLR Discussion 4 08-21-2010 05:53 AM
Pentax K-x Audible Noise in LiveView omardalian Pentax DSLR Discussion 14 06-03-2010 11:45 AM
how does the lack of AF impact video recording? Keebler Video and Pentax HDSLRs 17 02-13-2010 11:44 PM
Liveview audible noise MM#8 Pentax DSLR Discussion 7 08-24-2009 08:52 PM
All times are GMT -7. The time now is 05:22 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
