05-11-2013, 10:01 AM   #1
SR and Video
Hi if you can notice in my video shoot, SR is turned on, Then there is this small shaky effect when my hands are moving most specially in close up shoots.. SR should be turned off whenever in video mode. here's the youtube link.
05-11-2013, 10:06 AM   #2
I purchased the K-01 the day before the wedding, and tested it in my friends. I forgot to research about the video mode settings before using. my fault. :-)
05-11-2013, 10:58 PM   #3
That's a lovely video, well done
Yes I see the shakes.. Certainly better footage can be got without SR switched on when using a tripod, but it's kind'a there to help with hand held usage. I've not seen that effect with my K-01 when using video mode.. I assume it the same on the original clips from the camera and not something introduced in PP ? (which software did you use?)
05-12-2013, 12:19 AM   #4
Thanks sir!
I used PP to edit. its the same SR effects with the original clips.
05-12-2013, 03:22 AM   #5
QuoteOriginally posted by booglesigwa Quote
I used PP to edit.
Sorry, which software is PP?
07-15-2013, 06:30 PM   #6
adobe premier pro cs6.
k-01, k01, mirrorless, pentax k-01, sr, video, youtube
Video mode SR impact ScooterMaxi Jim Pentax K-01 4 01-07-2013 03:10 AM
K-R's SR is jiggling in LV and Video. Kryscendo Pentax K-r 2 05-08-2012 08:05 PM
K-r video, and SR? Cinders Pentax K-r 2 02-23-2011 05:01 PM
Pentax video samples? (Esp. ~ 300mm and SR) emr Video and Pentax HDSLRs 5 02-28-2010 05:21 AM
Thoughts: SR + Video? ewalk Pentax DSLR Discussion 12 02-18-2009 11:24 AM
All times are GMT -7. The time now is 02:11 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
