05-17-2013, 11:52 AM   #1
LeRolls's Avatar
Pop-Up DSLR Flash Diffuser for K-01
Just curious if anyone knows or has experience with an on-board pop-up flash diffuser for the K-01? Just looking for something that would give me a more balanced/diffused fill light for portraits and such. I've seen these but don't know if they'll attach properly to the K-01:
Amazon.com: IR Wireless Remote Control + Pop-Up SLR Flash Diffuser + JB Digital Microfiber Lens Cleaning Cloth for PENTAX Q, PENTAX DSLR 645D, K-m, K-r, K-x, K-01, K-5, K-7, K10D, K20D, K100D, K110D, K200D, K2000 *ist (D, DL, DL2, DS, DS2): Camera &
05-17-2013, 11:56 AM   #2
JinDesu's Avatar
I could order one and try it out.
05-17-2013, 11:57 AM   #3
Docrwm's Avatar
I seem to recall that if you use the hot shoe to hold a diffuser the flash on the K-01 refuses to fire. Can anyone confirm this, I don't have access to my popup diffuser just now.
05-17-2013, 12:04 PM   #4
LeRolls's Avatar
QuoteOriginally posted by Docrwm Quote
I seem to recall that if you use the hot shoe to hold a diffuser the flash on the K-01 refuses to fire. Can anyone confirm this, I don't have access to my popup diffuser judt now.
Well, that would certainly be unfortunate, rendering these little jobbies completely useless.
07-24-2013, 04:47 PM   #5
Reviving an old thread, but... did anyone find out the answer to this? Will the K-01 flash refuse to fire if you use the hot shoe to hold a diffuser?
07-24-2013, 06:10 PM   #6
Yes i have this exact kit from my k100d and it works flawlessly on the k-01. No issues
07-25-2013, 07:47 AM   #7
QuoteOriginally posted by glealisla Quote
Thanks glealisla. Good to know!
07-25-2013, 09:59 AM   #8
LeRolls's Avatar
Thanks for the replies! I went ahead and ordered it.
07-25-2013, 12:11 PM   #9
you wont be disapointed, while we are at it let me ask you this. What are colored diffusers supposed to be used for? I have only used the white one, but in what occasion would I need to use orange and blue?
07-25-2013, 12:19 PM   #10
Docrwm's Avatar
Different colors are used to balance for different light sources - florescent for example. With built in WB in cameras this is less necessary than in the past if you shoot in RAW.
07-25-2013, 12:45 PM   #11
Also ordered one from Fleabay (just the diffuser) for $2....
07-26-2013, 06:49 AM   #12
wanderography's Avatar
I own that exact one and used it on my K-01 for a little, all it did was soften the flash, but not even in a good way, as if you just lowered the flash power in camera so in the end it's kind of useless regardless of what camera you use it on.
07-26-2013, 07:22 AM - 1 Like   #13
mrNewt's Avatar
When you remove the cover for the flash shoe you will see that under the left lip there is like a small contact plate that moves up - when press down it disables your built-in flash because its assuming that you have installed an external flash.
It doesn't get disabled when you have the flash shoe cover because you will notice that the cover has the left side lip cut - that's the reason why is cut.
So... if that pop-up flash diffuser doesn't press down on that contact plate, I am sure you will have no problems... however, if it doesn't work, that means that the contact is pressed and you most probably have to cut from the diffuser's "foot" to make sure the contact is not pressed.
07-27-2013, 04:57 PM   #14
LeRolls's Avatar
Just received the $8 kit from Amazon today and it works fine. I've only taken a few shots with it but so far I think I like it. I tend to use the on-board flash at the lowest setting (-2) and this softened it and created a more even fill flash. I could see using it in an indoor setting or for impromptu/unplanned portrait sessions (whole kit fits nicely in my messenger bag along with the cameras so no real reason not to keep it with me). I'll probably end up taking it along to conventions where the indoor lighting is quite poor. The added bonus was they also included a remote trigger from JJC which I like using for long exposures. Always good to have an extra one of those laying around.
diffuser, dslr, flash, k-01, k01, mirrorless, pentax, pentax k-01, pop-up
K-7 Pop up Flash Danny Delcambre Pentax DSLR Discussion 9 01-25-2012 01:45 AM
K20D pop-up flash doesn't pop up! ducdao Pentax DSLR Discussion 3 11-29-2011 07:57 AM
DIY: Diffuser solution for pop-up flash jmbower Do-It-Yourself 29 12-09-2009 06:26 AM
Diffuser solution for pop-up flash? jmbower Flashes, Lighting, and Studio 27 08-29-2008 08:56 AM
Pop-up flash diffuser? lapeen Flashes, Lighting, and Studio 16 09-21-2007 02:44 PM
All times are GMT -7. The time now is 06:21 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
