08-18-2013, 03:46 PM   #1
mns's Avatar
Multiple pics !
I am new to K01
Now when I press the shutter I get 3 pics ( it looks slightly different exposures !!? )
I tried to find a way to fix it but I found nothing in the menus or when searching the user's manual
any explanation or advice
Thanks
Mustafa
08-18-2013, 04:02 PM   #2
fotogaffer's Avatar
Hi mns. My guess is that you have the drive mode set to exposure bracketing. Turn the camera on, push the drive mode button which is the button on the right hand side of the OK button, then select single frame shooting. Good luck! Welcome to the forum and the K-01 - great camera - I'm sure you will enjoy it!
08-18-2013, 04:38 PM   #3
Na Horuk's Avatar
Hey, welcome.
Thats right. The buttons around the OK button are menus. One of them allows you to select drives modes: bracketing (can be very useful in some situations, or if you want to manually process HDR), remote timer and then there is also burst mode. You probably want it set to burst mode LO or Single shot.
Feel free to take a look at the link in this thread:
https://www.pentaxforums.com/forums/pentax-k-01/179225-k-01-recommended-settings.html
And if you have any more questions, just search the forums or make a new thread
Good luck!
Edit: Btw, you can also download the manual in pdf format, so you can easily search it, and even carry it with you on a mobile device.
08-18-2013, 09:06 PM   #4
mns
mns's Avatar
Thanks already done
08-19-2013, 12:19 PM   #5
mns
mns's Avatar
QuoteOriginally posted by fotogaffer Quote
Thanks a lot
08-19-2013, 01:52 PM   #6
TaoMaas's Avatar
I was having this same problem with my K-01 a while back and this is exactly what I'd done. I had somehow accidentally switched it off of "single frame", which is how I normally use it. Took me a while to figure out what was wrong.
k-01, k01, mirrorless, pentax k-01, pics
Multiple exposure techniques benhai Photographic Technique 6 07-18-2012 10:15 PM
Sports Dance Comp (multiple photos) crewl1 Post Your Photos! 6 02-07-2012 02:15 AM
Pics in a park by K20D+DA*50-135mm (Many PICS) dsport Post Your Photos! 2 10-18-2008 10:51 PM
multiple multiple exposure Donald Post Your Photos! 6 05-17-2007 07:43 PM
All times are GMT -7. The time now is 08:55 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
