08-26-2013, 06:11 AM   #1
Remote trigger from behind
If you would like to trigger your K-01 from behind, there is a simple solution. . . . . . . if you have large amounts of camera junk in the basement like I do.
Here's what you need:
- old folding flash
- makeshift mounting hub
- #12 or heavier electric wire
- cheap glue clamp
Clamp the reflector to the tripod - bend the wire to the correct position - fire away
Canon PowerShot SD780 IS  Photo
08-26-2013, 06:39 PM   #2
I found it works perfectly fine just like this:
k-01, k01, mirrorless, pentax k-01, wire
K-30 remote triggering from behind NRV Shooter Pentax K-30 & K-50 9 12-27-2012 10:17 AM
Can't use V5 (or other remote trigger) as shutter trigger in hot shoe above 1/180? jake14mw Flashes, Lighting, and Studio 14 07-16-2012 04:14 PM
Enable remote trigger on K5 debmalya Troubleshooting and Beginner Help 2 06-16-2012 05:58 AM
Flash and Remote Trigger arnie0674 Photographic Technique 8 03-03-2012 04:06 PM
Remote trigger vs onboard k-x wireless trigger irishwhite Photographic Technique 3 03-06-2011 04:36 AM
All times are GMT -7. The time now is 07:57 AM. | See also:, part of our network of photo forums!
