Originally posted by RonHendriks1966 Wow looks very weard. No idea on that, but my best guess would be to use the seald K-5 with DA*lens combo. No idea if this would work on that altitude. I think you will risk the same problem by repeting this test with K-01. On the other hand, maybe it doesn't, since it workt for a good time, but didn't get back to normal functioning when up in the air after the fault started. So maybe that is just a risk to take and maybe it only accurrs next time much later or not.
The K-5 would be a fair alternative. It's hard to say if the extra sealing would help. If there was condensation inside on the sensor then perhaps. If it was due to cold, then likely not. The k-01 is lighter and has a built in intervalometer. I'll see what happens when testing the k-01 in the freezer and if the problem occurs then I'll have to come up with some way to heat the camera.
