I really like this camera. Image quality is great, and I just have one complaint--the way the viewfinder screen disappears in bright outside situations. Has anyone come up with a solution? I am thinking that an add-on viewfinder to insert into the hotshoe would be a good idea. It could be permanently zeroed in at, say 50mm, which ought to be good enough for lots of walk around photography. You would not be able to frame the shot exactly unless using 50 mm lens (or equivalenta full-frame), but at the very least it would help make sure you are zeroed in on the center of the frame you are trying for.
