11-16-2013, 08:12 PM   #1
andrewrw66's Avatar
Night Time Shots
I have the K-01. I have used Manual, Av and Tv modes to change aperture, shutter speed and iso. I specifically wanted to take a shot of the full moon tonight overlooking the ocean. It would not snap a photo no matter what i did. It would snap one if i had a lighted object other than the moon in the view.
Any advice ? What am I doing wrong ??
11-16-2013, 08:56 PM   #2
dms
The moon is a very small area--and thus the meter see's mostly dark sky. Instead use manual exposure and (for a full moon) set about 1 stop more exposure than a full sunlight scene--e.g., 1/100 sec at f/11 and iso 100. Then adjust after viewing the shot. The moon has a reflectance of about 8% as I recall, and it is seeing/reflecting sunlight. If it was 18% reflectance it would be a middle gray. If you want more the scene to be visible, and you don't mind overexposing the moon, work up in exposure--but if more than about 3 stops overexposed, the moon will be featureless.
11-16-2013, 09:06 PM   #3
konraDarnok's Avatar
If you're setting everything manually, and the menu is set for focus priority, you probably need to set the focus switch on the front of the camera to manual focus. Then the shutter with actuate.
11-17-2013, 04:50 PM   #4
andrewrw66's Avatar
QuoteOriginally posted by dms Quote
Thank you. I actually printed your thread out so i can remember what to do next time
11-17-2013, 05:20 PM   #5
I am going to assume that your metering mode was set to average over the entire frame. If you switch to spot metering, then it will meter to just the center spot. Put that on the moon and you will meter correctly and not average in the rest of the black sky....
11-17-2013, 11:59 PM   #6
Try it again tomorrow night! And let us know what happens. Failing that, there is also Photoshop, which is great fun too. And traditional... didn't Ansel Adams do a little darkroom magic with that iconic 'Moonrise, Hernandez, New Mexico' image?
k-01, k01, mirrorless, moon, night shots, night time, pentax k-01
Thematic Night Time is the Right Time! Post night shots here. bbluesman Mini-Challenges, Games, and Photo Stories 1004 2 Days Ago 04:55 PM
Cityscape Night-time shots faceless_el Post Your Photos! 4 08-17-2013 01:25 PM
Night time shooting? clearlybored Troubleshooting and Beginner Help 22 03-14-2011 06:06 PM
Architecture Night Time Urban Shots bigjonnee Post Your Photos! 4 03-02-2010 04:41 PM
2 night time garden shots robbiec Post Your Photos! 3 06-08-2009 02:48 PM
All times are GMT -7. The time now is 02:59 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
