01-22-2014, 02:41 PM   #1
OnTheWeb's Avatar
K-01 Command Button popped off
The command button (cover) on my K-01 just popped off Well, actually the knob was turning slightly unsmoothly and it just lifted off. Not broken or anything. It looks like some light glue was supposed to hold it in place...
What type of glue should I use to reattach it? Contact cement? PICs:
01-22-2014, 02:47 PM   #2
seventysixersfan's Avatar
see these other entries for tips and suggestions
this has not happened yet to my K-01 but now I'm getting a bit paranoid that it might happen eventually (I'm OCD by nature). Is there something that you and others are doing that contributed to the mode dial coming off? Or is it totally random?
01-22-2014, 03:44 PM   #3
Mine fell off about a month ago. I used a small amount of super glue to put it back on. Seems to be working fine.There are many people that have had this happen to them. It is too bad this is such a common problem on an otherwise well made camera.
01-22-2014, 03:49 PM   #4
Na Horuk's Avatar
Ive never heard of this problem and then suddenly in the past month a bunch of threads about it appear.. weird timing
01-22-2014, 03:56 PM   #5
Poor design, not tested well enough. Stupid to rely on a dab of glue for a quality consumer product like this.
I'll definitely pin mine should it come off again.
01-22-2014, 05:34 PM   #6
Marketplace Reseller
innivus's Avatar
Just to say, I convinced my father to buy a K-01 when it was on super sale... and this knob fell off after a day of use!
(this was AFTER the first one he bought refused to do anything but Av mode... took it back to Adorama, but that made Pentax QC 0/2 in this case...)
And, just to add, I used a dab of Gorilla glue and it has worked perfectly ever since. Just be sure to use only a dab, otherwise you'll glue it in place!
01-22-2014, 07:20 PM   #7
tzrenz0's Avatar
Mine fell off as well. I only use it in manual mode. So I didn't put it back on.
01-27-2014, 02:22 AM   #8
Chris Stearns's Avatar
Same here. Fell off a month ago. Super glue gel has worked so far.
button, command, glue, k-01, k-01 command button, k01, mirrorless, pentax k-01
K-01 and Green Button Placement Spodeworld Pentax K-01 22 02-20-2013 12:38 PM
K-30 Off for Warranty Repair of OK Button lawsonstone Pentax K-30 & K-50 2 02-09-2013 07:29 AM
How do you think they pitched the idea of K-01 to Pentax High Command? Reportage Pentax K-01 26 12-24-2012 02:15 PM
K-5 - Lens removal button popped off, now what? blackcloudbrew Pentax K-5 29 08-24-2012 12:12 AM
K-01 and the Green Button nparsons13 Pentax K-01 30 03-28-2012 11:53 AM
All times are GMT -7. The time now is 06:44 AM. | See also:, part of our network of photo forums!
