02-04-2014, 11:32 AM   #1
Viewing aid for rear LCD
I am a new K-01 owner, and I would like some advice about a hood for viewing the rear LCD screen in bright light. The relatively dim LCD is easily the camera's greatest weakness, IMO. I know that I have seen references to such devices, but I cannot find them at the moment. Are any people using them, and are they more trouble than they are worth?
Thanks,
Rob
02-04-2014, 11:44 AM   #2
I just started using the VF-4 from these people:
Photography and Cinema - Store
Adds a lot of bulk to the camera, but it works.
02-04-2014, 12:27 PM   #3
I just discovered that the brightness of the LCD screen can be increased, which makes viewing in sunny conditions much better. Still, I am interested in some sort of removable, collapsible hood device. Here is one that I found that seems to fit the bill. I like the fact that it attaches via the tripod socket and that it does not appear to have a plastic sheet to cover the LCD screen itself (at least I hope it doesn't). I already have one attached to my K-01.
Kaiser digiShield Folding LCD Hood for 3" LCD 206075 B&H
Rob
02-04-2014, 12:28 PM   #4
Those look to be very effective, but they are too expensive for a camera that cost me $250 used.
Rob
02-04-2014, 12:41 PM   #5
QuoteOriginally posted by robgo2 Quote
Rob
Well, I also got it to work on my future K-3 and whatever...certain situations it is easier to use LV even if I have an optical viewfinder available...
02-05-2014, 11:43 AM   #6
Here is a very straight-forward and economical device…
Delkin Devices DU3.0-M BLK
http://www.google.com/aclk?sa=l&ai=CsiWiHn_yUqmgMMy5yQGxx4DoA6LlpqoE2tSopBzy...w%3DDEDU30MBLK
02-05-2014, 05:53 PM   #7
TaoMaas's Avatar
Rob
I keep wondering why someone doesn't build one of those with a flip-down lens that you can use for fine focusing, like the hoods on twin-lens reflex cameras. It would basically be a folding lupe.
02-05-2014, 06:36 PM   #8
QuoteOriginally posted by TaoMaas Quote
The VF-4 I posted above does that (if I understand you correctly). I've seen others that do it too. You can use it as just a shade (albeit with giant folded over eyepiece on top) or with eyepiece magnifier that you can hold up to your face...
02-05-2014, 08:42 PM - 1 Like   #9
TaoMaas's Avatar
More like this one...where the lens is usually just folded up like one of the flaps, but can be popped into position when needed.
M8 Digital Camera  Photo
02-06-2014, 07:39 PM   #10
If wish they had put the LCD horizontal like that .. it'd be perfect on the K-01 brick !
k-01, k01, lcd, mirrorless, pentax k-01
K5 IIs Top LCD display viewing angle issue RGold Pentax K-5 & K-5 II 5 11-23-2013 11:16 AM
Thoughts on dropping rear LCD? twr Photographic Industry and Professionals 29 04-09-2013 01:25 AM
Correct viewing angle for LCD screen? Graham67 Digital Processing, Software, and Printing 2 10-31-2009 08:56 PM
LCD Viewing gordon_l34 Pentax DSLR Discussion 4 12-28-2008 03:25 PM
Recommendation: Protective Cover for K10D rear LCD wil_war@comcast.net Pentax DSLR Discussion 18 11-16-2007 08:46 AM
All times are GMT -7. The time now is 07:07 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
