02-07-2014, 06:44 PM   #1
OnTheWeb's Avatar
Anti-shake focal length settings
When you guys set the focal length on non-AF lenses, do you use the engraved focal length of your lens or the cropped, 1.5X, focal length? For example, you mount a 50mm Pentax-M prime... do you set the focal length to 50, or its cropped equivalent of 75mm?
Not a trick question. I would have set it to 50mm, but it occurred to me I was wrong once.
02-07-2014, 06:51 PM   #2
Canada_Rockies's Avatar
The camera makes the required conversions of motion magnification. Set the NR to the focal length on the lens. If you use 300 when the lens is 200, you will cause motion blur as the camera over corrects.
02-07-2014, 08:08 PM   #3
VisualDarkness's Avatar
FL is a lens characteristic and got nothing to do with the camera body. In short a 50mm is a 50mm no matter if it's on a mini-sensor, large format, laying on the table or when you look through it with the lens.
02-08-2014, 09:20 AM   #4
QuoteOriginally posted by VisualDarkness Quote
True enough, but the apparent motion on the output from a 16x24mm sensor is 150% of the apparent motion at a given output size from the 24x36 sensor. This is not because of the lens, the camera body or sensor size, but because of the increased magnification of the output product, printing a 24x16 inch print from 35 mm film, requires magnification of 16x; to print from APS-C the magnification is 24x. The apparent size of the shake is greater on the output from the smaller sensor.
02-08-2014, 09:26 AM   #5
Senior Moderator
Parallax's Avatar
Wouldn't just lo love to meet the guy that came up with the concept of "crop factor" or "35mmm equivalent" and string him up by his thumbs?
02-08-2014, 09:44 AM - 1 Like   #6
QuoteOriginally posted by Parallax Quote
Actually, it is not his thumbs that I would string him up by ....
02-08-2014, 10:29 AM   #7
Senior Moderator
Parallax's Avatar
50mm, anti-shake focal length, k-01, k01, length, mirrorless, pentax k-01
K10D - Setting Shake Reduction Focal Length With Manual Focus Lenses? stewart_photo Photographic Technique 30 07-28-2016 12:52 AM
anti-shake update stopped working krema Pentax Q 8 11-11-2014 05:12 PM
Inputting focal length of a variable lens on my K-x. / Shake reduction problems? TexasLangGenius Pentax DSLR Discussion 7 11-26-2010 11:35 PM
K100d - Shake Reduction Focal Length? Russell W. Barnes Pentax DSLR Discussion 5 05-08-2009 07:09 PM
Manual lens focal length for shake reduction Riverlady Troubleshooting and Beginner Help 20 05-05-2009 03:16 PM
All times are GMT -7. The time now is 02:33 PM. | See also: NikonForums.com, part of our network of photo forums!
