Originally posted by Steve.Ledger Well, now we have a new way to describe Movie SR. It induces a heat-haze effect
It was 30+ degrees. Not bad for the end of March.
I shot some around Sunset with the same lens yesterday, turning SR on and off to see if it can smooth out the vibrations from fingers touching the lens for focus on locked off frames, will have to see if it can cope, not expecting it to. I think if I use this lens on a short film or the like, it's going to have to be for locked off shots, or servo driven movements to eliminate vibrations, same as in broadcast 'box' lenses used for sporting events.
Describing the cmos jello as 'like heat haze' is probably an accurate method, ditto the SR wobbles.
Edit: for those that aren't aware, this is a Box lens, shown with camera, CCU and remote.
