Originally posted by vonBaloney What lens is this?
Hi Von, this is the Rokinon 85mm F1.4. Yes, very narrow DOF even at F3.2 which this was shot. But, I'm pretty good with MF so it surprises me it would be a focus miss. I've also been using some diopters with this lens recently, and that is some seriously tricky MF. But, the bluejay shot was just the normal lens.
Originally posted by Adam It looks like that branch might partially be covering the bird, as the one he's sitting on seems perfectly sharp. Live view is previewed wide-open, so that's why the final result may have changed.
HI Adam, pretty sure this was a clean shot to the bird but, yes, a branch would produce that effect so I'll double-check and see if that was the culprit in this case.
Thanks
