03-12-2014, 10:21 AM   #1
OnTheWeb's Avatar
Delkin Du3.0"-M LCD Shade is nice
Thanks to the PF for pointing out this little gem of an LCD shade. Love my K-01, but in bright light it can get tough to see. The very inexpensive Delkin shade helps greatly, once you get past the fact you have to stick something on to your camera. It flips open and closed easily, and slides right off when you don't need it (the mount rectangle stays on the camera always, of course) It has a clear cover that protects your LCD screen always and doesn't seem to reduce the LCD brightness at all. Cheap and effective.
Here it is in action and you can see how it shades the LCD nicely (or slides off in 2 seconds if needed):
03-12-2014, 09:34 PM   #2
Canada_Rockies's Avatar
I mounted one on my K10D, and it really helps a lot. (Different size, of course). I broke the cover mount pins, and promptly bought another. It keeps nose grease off the LCD as well. It doesn't show on the metal cover at all.
03-14-2014, 04:43 PM   #3
OnTheWeb's Avatar
QuoteOriginally posted by Canada_Rockies Quote
Have you, by chance, ever removed the sticky mount? I ask because I may want to peel mine off and put it back on in the right spot
03-14-2014, 06:05 PM   #4
I'm no fan of these because you've totally lost the ability to hold the camera at a different height other than pretty much eye level and still see the screen.
I've seen them and tried them with other cameras (not mine) and found they did not stop reflection one iota. It is reflection when out in bright sun which is the biggest issue.
Yeh, I am no fan of 'sticking' stuff on my cameras.
Sorry for the negative post but really I find many 'accessories' useless gimmicks.
03-14-2014, 07:12 PM   #5
The sticky mount will come off, but in pieces. When I broke mine, I replaced the whole thing.
Steve - the sticky on this item is on the frame around the screen, not on the screen. I have been using them on the same K10D since 2009, and I do not find that I have to have it exactly lined up to see the LCD, and when indoors, often remove the shade itself so that I don't have to keep flipping it open. Reflection in the bright sun is as simple as turning the camera slightly so that the shade does in fact shade the LCD.
All that said, we all have our own opinions, and I am in no way denigrating yours.
03-14-2014, 08:44 PM   #6
OnTheWeb's Avatar
Well, I haven't tried the anti-glare screens, which I'm sure are helpful but more expensive, but that's because with the shade I haven't had any problem using the K-01 outdoors and haven't need to.
So yes, we all shoot differently and have different needs.
03-15-2014, 07:13 AM   #7
nparsons13's Avatar
Keep an eye on your Delkin shade. It can be knocked off easily; it doesn't take rough handling to do it. I lost my first one that way. Fortunately, they are fairly inexpensive.
The brightness of the LCD can be adjusted upward to counter bright sunlight to some extent. That plus the Delkin shade is all I've needed.
camera, delkin, delkin du3.0"-m lcd, k-01, k01, lcd, lcd shade, mirrorless, pentax k-01, shade, slides
LCD Hood or Shade? ibkc Pentax K-01 29 03-03-2013 12:13 PM
For Sale - Sold: SMC Pentax-M 135mm f3.5 (nice lens with less-than-nice case) cheekygeek Sold Items 2 04-13-2012 10:08 AM
Zenitar-M 50 1.7 is it nice or just mine is :) simbon4o Pentax SLR Lens Discussion 5 04-02-2012 09:46 PM
LCD-screen shade Bankebrett Pentax K-01 3 02-17-2012 01:50 AM
Which flip up Delkin LCD protector for my K10D? Techguy Pentax DSLR Discussion 2 01-13-2008 11:47 AM
All times are GMT -7. The time now is 08:04 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
