Thanks for the feedback all. To be clear, AF seems accurate. This is not about needing to callibrate AF - something you can't do (and shouldn't have to do) on the CDAF-only K-01 - but only about, for example, pre-focusing the lens manually in the right ballpark if you know a shot is coming up to ensure quick AF. (Yes, I know the DA70 is pretty quick to focus.) I've just grown very used to hitting OK to magnify with a MF lens which, combined with peaking, works very well for me. I guess it's not a must-have, but I was a bit disappointed when I found out I couldn't do this with Quickshift. (I also read recently that Fuji has done some neat tricks at least on the XT-1, where it will automatically switch view mode to a manual focus assist mode as soon as you start turning the manual focus dial...)
Originally posted by lister6520 I couldn't get it to do exactly what you need but a possibly useful alternative. In the Live view options there is one called AF autozoom. (...)
Ah yes, thanks! This option is also on the K-01 and should be useful to do the reverse of what I was thinking of - fine-tuning manually
after the AF has been activated.
