Originally posted by Adam Hmm, since the K-01 uses CDAF, there is no AF module and therefore nothing that can really be adjusted by a repair shop.
The best CDAF performance is obtained with a large AF area, as opposed to the smallest setting in select mode, for instance. Under what conditions have you been experiencing issues?
I'm going to play with it some more but it seems to work the best with the 40mm xs and that isn't even consistent. I have experienced the focusing issues in a variety of situations: low light, lots of available light, flash, no flash and with a variety of lenses. I have noticed that focus improves with the AF assist light on but that, too, is not consistent and I can't use that with several of my birds. Items I focus on are not in focus. Focus on the same thing with the K-7 using the same lens and it's in focus. I have increased the size of the AF box but maybe should increase it even more? I've also used manual focus and looks like what I want is in focus but in the resultant photo that's not the case. I also don't have this problem on my G3 so I don't think it's me.
---------- Post added 09-28-14 at 01:30 PM ----------
Originally posted by RonHendriks1966 Have you tested this good first? In good light. With the latest firmware?
Yes, very good light outdoors. I updated the firmware a few months ago, not sure it's the latest, though. Will check on that. Wanted to test out the 43 especially at 1.9. At this point, K-01...fail, K-7...excellent.
