Originally posted by GerryL I see the "pin" that the flash holds down while (the flash is) on the down position never did try if holding it down manually will disable the flash. Maybe you have to push the "catch" back also as you push the "pin" down? There might be something wrong electrically. Although the catch is mechanical in nature, actuating it is an electrical thing.
Thanks. I tried holding the catch in different positions while holding the pin down but it didn't make any difference. I think you are right that it is an electrical problem.
