01-20-2015, 10:28 AM   #1
Resident fiddler
LensBeginner's Avatar
Stop down permanently a.k.a. DoF preview?
As per title.
Is there a way to make the Green Button "stick" on a K-01?
I want to test an M lens for focus shift, and need to have it stopped down to where I put the aperture ring... auto-gain is disrupting everything in the interest of the best possible gain...
NVM, I'm an id***, button customisation on red button. :-)
01-20-2015, 11:36 AM - 1 Like   #2
Tap the mount of M lens, to block the contacts on the camera. Without this information, camera will not try to keep the lens wide open and you will get a M42-like stop down lens. And you can shoot at Av. Most time the camera can get correct exposure.
01-20-2015, 12:07 PM   #3
On the K-01 with a manual lens, you can do it in M mode ("true" M mode -- ISO must be set to a fixed number) by holding the EV button (+/-). That might be undocumented, not sure, but I was glad to find it...
01-20-2015, 12:16 PM   #4
Na Horuk's Avatar
So why not just go to the Menu, customize buttons, and select DoF preview? Then the camera will stop down the lens to the selected aperture for the whole time you hold the button.
01-20-2015, 12:19 PM   #5
Resident fiddler
Wow that's true!!!
No need to map the red button then... even though I didn't use the focus peaking feature...
---------- Post added 01-20-15 at 08:21 PM ----------
That's what I found on page 102 of the manual... after I realized I could look it up!
02-09-2015, 03:48 AM   #6
PiDicus Rex's Avatar
QuoteOriginally posted by LensBeginner Quote
Or, just swing the dial around to video (assuming your firmware is up to date) with the exposure set to M in the Video Mode Menu.
Set the exposure etc to what appeals, then memorise those settings and swing the dial around to M, input those settings, press shutter.
button, k-01, k01, lens, mirrorless, mode, pentax k-01
Odd behaviour from Super A - aperture doesn't stop down Jonathan Mac Pentax Film SLR Discussion 15 10-21-2014 11:07 PM
Where does DOF increase in relation to a focus point when stopping down? Fat Albert Photographic Technique 13 10-18-2014 06:49 AM
Possible to force K-5 to stop down to shoot when using non-A lenses? Sicariphus Pentax K-5 19 07-26-2013 10:48 AM
How to stop down an M42 on a K-mount camera scimitar12 Troubleshooting and Beginner Help 6 04-19-2009 10:59 AM
DOF Preview in K110D - lens stays stopped down when unmounted? fuzzybabybunny Pentax SLR Lens Discussion 5 12-02-2006 11:04 PM
All times are GMT -7. The time now is 01:13 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
