12-14-2015, 10:32 PM   #1
Pentax K-01 for live feed
Hi. I just want to ask if the Pentax K-01 can be used as a camera for live feed. I want to try if the video can be projected on a projector and at the same time record the video.
Thanks
12-14-2015, 10:45 PM   #2
See:
https://www.pentaxforums.com/forums/138-pentax-k-01/257846-hdmi-output.html
12-14-2015, 10:52 PM   #3
johnhilvert's Avatar
Sadly no.
According to the manual, "The camera stays in playback mode while the HDMI cable is connected to it. Remove the HDMI cable to enable shooting." (p.187)
12-14-2015, 11:15 PM   #4
Okay. Thanks!
12-14-2015, 11:29 PM   #5
Nopes...
QuoteOriginally posted by dubdub Quote
Nopes... I just tried it. The camera switches to playback only mode (kind of enforced). Tried various combinations also as in Turned on/off with the cable attached, turned on in video mode, cable attached while in while in live view mode, etc. So HDMI is only playback and no live feed . It would be awesome if this HDMI could be used to pretty much replace the built in LCD. A firmware update may be???
Also the mini HDMI connector that you will need to connect needs to be very slim. I had a mini HDMI to standard HDMI adapter that I had to improvise (splice it on one side) to make it sit into the mini HDMI port properly on K-01. See attached picture.
So you (we) are out of luck.
12-15-2015, 10:53 AM   #6
roberrl's Avatar
Just a suggestion but you could use the PC/AV socket. The quality is not great certainly not HD but it does run alongside the recording.
I just tried it on my K-01 and TV, using a Pentax to phono cable whose origin I don't remember, and it worked quite well.
It simply shows whatever is on the live view screen.
I guess the internal processor can't encode for recording and encode for HDMI at the same time.
01-01-2016, 10:51 AM   #7
Right, there's another thread around here on using the PC/AV socket. Make sure you get/have the right cable. I played around with it once and the video quality is pretty good.
02-02-2016, 11:33 AM   #8
PiDicus Rex's Avatar
Yep, your only option is the analog output, the K-01 is particularly hobbled with the "force to playback" going on, but even in playback, the HDMI output doesn't display what you've recorded, if you're in a PAL country - 1080p25 is displayed as 1080p30.
The Analog output is Standard Definition only with the same overlays visible on the cameras screen. It's okay for a Directors Monitor feed on a CRT, but I wouldn't stream from it.
All Pentaxes have really bad HDMI implementation - the K-3 comes up as outputing 720p60 when recording 1080p25. I tested all this a while back, there are posts about what I found.
Even the 645Z has unusable HDMI, for when it comes to recording to a Atomos Shogun or similar.
Add that to the Sensor Shift being switched off in Video Mode, and you get a whole heap of bad firmware reasons to not buy another Pentax, even with the fantastic image quality in stills, the full dynamic range in video (which is then compressed waaaaay too far), and the great range of lenses available to us.
feed, k-01, k01, mirrorless, pentax, pentax k-01, video
K-3 vs K-01 Live View Focus Speed - K-01 Wins! rmtschanz Pentax K-3 25 12-07-2015 06:02 PM
K 01 conected to ext live view LCD Cata'S Pentax K-01 6 02-26-2015 12:53 AM
K-01, HDMI and live view Hayflick Pentax K-01 6 12-20-2012 12:37 AM
Shooting with a K-01 if I hate live view on my K-5? Codazzle Pentax K-01 16 12-12-2012 07:28 PM
Does K-01 enable you to disable AF zooming in Live View Basset Pentax K-01 7 02-04-2012 07:54 AM
All times are GMT -7. The time now is 03:53 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
