Show Printable Version 4 Likes Search this Thread
06-24-2016, 05:04 AM   #16
QuoteOriginally posted by Achromatter Quote
Yes, they must have recently lowered the price, it was $135 at first.
I ended up caving and bought one at the $30 price, as I didn't see any other options materializing. Now I have to figure out how to attach it, so it doesn't come off again.
I think $30 with free shipping is a fair price.
I would assume that, when the knob arrives, you'll be able to figure out a good attachment method (which you'll share with us, right?).
06-24-2016, 08:24 AM   #17
THoog's Avatar
A small blob of clear silicone sealer/glue/stuff has held two of mine on for... well, longer than the original glue.
06-24-2016, 11:47 AM   #18
monochrome's Avatar
  1. There is a pin on the underside of the dial that fits in a hole on the controller. The Marlins on the dial will then orient correctly with the electronics
  2. Clean residual glue off the control surface (it is like rubber cement or silicone caulk).
  3. Attach your new dial with a dab of more aggressive glue, or just another dab of silicone caulk. Pliobond works well.
06-25-2016, 01:00 AM   #19
I had reattached the original knob with "high-strength" hot-glue, after it fell off. I cleaned both surfaces thoroughly & roughed up the inside of the aluminum knob. Didn't work, I lost it somewhere. This time I was thinking of trying some type of epoxy, I had heard of something called Tite-Bond or something like that.
The new knob comes with the plastic selector shaft(?) already attached, but I am NOT taking my camera apart. And if it's glued on with the same crap they glued the ones that fell off with, it should easy to separate & it would have just come off again anyway, like the original. I just have to wait for time to go to Home-Depot and see what adhesives they have.
06-25-2016, 01:14 AM   #20
ChrisPlatt's Avatar
When I worked in camera repair Pliobond was our go-to adhesive in most cases.
It holds well but unlike some other adhesives allows disassembly if necessary,
e.g. servicing camera for some other problem later on.
Chris
06-25-2016, 06:48 AM   #21
Rupert's Avatar
Oh thank heaven! I misread this and thought it was the Crop Mode dial on a K1. That is my favorite dial! I went into a panic, my heart raced, I was in a cold sweat and my blood pressure skyrocketed.
Glad it was just another case of my confused speed reading....and glad you found a replacement dial!
Best Regards!
07-26-2017, 07:41 PM   #22
Oh Woe. After just purchasing a used K-01on ebay to convert to IR, I came across this thread. In checking with the $30 ebay mode knob supplier, I found they quit offering as of March 2017 - just missed getting a spare by a few months. I really, really hope they come across more to offer.
All is not sad however. Now I know the first thing to do when I get my K-01 (after looking to see if it has its mode knob) - stick that sucker with some super fantastic something so it will never come loose!!
09-19-2017, 01:38 PM   #23
I keep tugging at mine and it seems like it's on there as solid as ever. I wonder if high heat or something environmental causes it, my camera has not been in too many temperature extremes. I hope I didn't just jinx myself!
09-25-2017, 11:19 AM   #24
I'm seeing the same as rmalbers. I gave a test tug on the knob of the K-01 I purhased and it seems pretty well anchored. Just the same, I'll keep an eye on it, but for now I'm not removing it just to put some adhesive on it. I hope I don't jinx us both!
08-03-2018, 02:12 PM   #25
It appears on EvilBay again, $30 apiece. Just click the link in #2 post to find it.
08-04-2018, 09:45 AM   #26
QuoteOriginally posted by jcdog2006 Quote
That one is a 3D printed dial and appears to be translucent plastic (hard to read modes), however some "refurbished" OEM dials are available here:
https://www.ebay.com/itm/Pentax-K-01-Digital-SLR-Mode-Dial-Replacement-Repai...-/152710481100
Or
https://www.ebay.com/itm/Pentax-K-01-Digital-SLR-Mode-Dial-Replacement-Repai...-/332144416032
but get ready for sticker shock.
08-25-2018, 12:09 PM - 1 Like   #27
QuoteOriginally posted by Bob 256 Quote
Pentax K-01 Digital SLR Mode Dial Replacement Repair Part Genuine 77560.0A331 | eBay
Or
Agree to your point, that one available @$30 is hard to read. But to spend $70 or $90 for a ~$200 K-01 seems too much to me(Sorry for being cheap........)
So, this is what I did to make it a little bit more useful..........
PENTAX K-1  Photo
k-01, k01, mirrorless, pentax k-01, purchase mode
Pentax k-3 replacement mode dial gbandi Troubleshooting and Beginner Help 4 07-11-2022 11:08 PM
GR mode dial and menu glitch indy Ricoh GR 3 03-04-2016 08:38 PM
Mode dial not working properly? wralyn Troubleshooting and Beginner Help 3 11-21-2015 02:32 AM
Mode dial right vs. left hjoseph7 Pentax DSLR Discussion 24 02-17-2015 08:35 PM
Mode Dial Problem nrh771 Troubleshooting and Beginner Help 5 11-03-2014 02:44 AM
All times are GMT -7. The time now is 06:21 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
