08-01-2016, 03:52 PM   #1
johnhilvert's Avatar
Pentax K-01: Can P-Line be configured?
Dear K-01 legends,
Is it possible to configure the Program Line (P-line) option when setting the Green Button's actions in button customisation?
I can vary the P-Line (Program line) on my K3 through various options including normal, depth of field preference, shutter speed but I can't work out how to do it with my Pentax K-01.
08-01-2016, 04:22 PM   #2
AFAIK you can only change the program line on Pentax's flagship line (K-1, K-3, K-5, K-7, K20D, K10D, *ist D).
All other cameras that have a SCN mode dial setting (such as the K-01, K-30, K-50, K-70, K200D, K-x/K-r/K-m,*ist DS/L) that provides access to alternate program lines, but they can otherwise not be selected for P/Tv/Av/M shooting.
08-01-2016, 04:42 PM   #3
My experience says Adam is right, and I've accepted as one of the puzzling things about Pentax P-line on cams other than the flagships. My other great puzzler is why K-01 flash implementation is the only camera that shows "Manual Flash" in the flash menus, rather than "flash on," and how its behavior differs.
08-01-2016, 05:14 PM   #4
monochrome's Avatar
In my experience it appears Pentax cameras have two software sets; mid-range and flagship. The primary difference seems to be fewer manual adjustment settings in the mid-range. For instance, on my K-01 M is buried under TAv.
08-02-2016, 12:52 AM   #5
Thanks, all.
So if P-line can't be configured, Do I assume it just means it's set to normal exposure ie a balance between ISO, Shutter speed and aperture?
Or might it be the MTF setting for the particular lens? In my case it's the Pentax 40mm F2.8 ltd version.
The reason I ask is that apart from OFF, the alternatives to P-line for the green button are just. Av-shift and Tv-shift?
button customization, k-01, k01, line, mirrorless, p-line, pentax, pentax k-01, program, program line
Baffled: Pentax MX-01 vs. K-3. A valid :P comparison OlafOlaf Welcomes and Introductions 9 03-25-2015 08:36 AM
Can K-01 Be Used As Flash Controller? nixcamic Pentax K-01 4 07-26-2013 04:19 PM
To be a Pentax k-01 head or not to be? Danas_Anis Pentax K-01 40 04-24-2013 05:03 PM
Why can it be so darned difficult to focus my K-01? rkymtnrider Pentax K-01 25 03-21-2013 07:44 PM
The Pentax K-01 is a special model, not a new line of cameras ogl Pentax News and Rumors 193 10-15-2012 08:35 PM
All times are GMT -7. The time now is 05:07 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
